Saltar al contenido principal
Repara tus cosas
Derecho a reparar
Tienda
Partes
No se especificaron partes.
  1. Gently use tweezers to detach the white vision wire harness, located directly under the feed tube.
    • Gently use tweezers to detach the white vision wire harness, located directly under the feed tube.
    • Another small tool or your fingers will work for this.
  2. Remove the two 1-1/4" screws on either side of the circuit board using a 3/32" allen wrench.
    • Remove the two 1-1/4" screws on either side of the circuit board using a 3/32" allen wrench.
  3. Separate the solenoid from the gun's body by gently pulling it upwards.
    • Separate the solenoid from the gun's body by gently pulling it upwards.
  4. Slide the metal body out of the plastic shell by holding one in each hand and gently pulling apart.
    • Slide the metal body out of the plastic shell by holding one in each hand and gently pulling apart.
Conclusión
Shane Villalpando
Miembro Desde 02/02/15
1,022 Reputación
10 Guías creadas
Equipo
Cal Poly, Team 8-42, Amido Winter 2015 Miembro de Cal Poly, Team 8-42, Amido Winter 2015
CPSU-AMIDO-W15S8G42
4 Miembros
10 Guías creadas
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 0
Ultimos 30 días: 0
Todo El Tiempo: 47
