Saltar al contenido principal
Removing the Phone Keypad
Qué necesitas
  1. Removing the Phone Keypad, Removing the Back Panel: paso 1, imagen 1 de 2 Removing the Phone Keypad, Removing the Back Panel: paso 1, imagen 2 de 2
    • Orient the phone so that the phone model and other descriptive information is facing upward.
    • Locate the two silver screws near the hinge where the battery is housed.
    • Remove the silver screws using a Phillips head #2 screwdriver.
  2. Removing the Phone Keypad: paso 2, imagen 1 de 3 Removing the Phone Keypad: paso 2, imagen 2 de 3 Removing the Phone Keypad: paso 2, imagen 3 de 3
    • Pull off the back panel of the phone.
    • Make sure you pull the cover off carefully in order to prevent damage to the back cover.
  3. Removing the Phone Keypad, Keypad: paso 3, imagen 1 de 2 Removing the Phone Keypad, Keypad: paso 3, imagen 2 de 2
    • Locate and unscrew the circled screw using a Philips head #2 screw driver or screw driver head.
  4. Removing the Phone Keypad: paso 4, imagen 1 de 1
    • Lift the motherboard away from the phone housing.
    • Be careful when lifting the motherboard. To prevent damage to the motherboard, gradually lift it from its place in the assembly.
  5. Removing the Phone Keypad: paso 5, imagen 1 de 2 Removing the Phone Keypad: paso 5, imagen 2 de 2
    • Now that the motherboard has been lifted out of place, the keypad can be accessed.
    • Using your fingers push the buttons from the the phone toward the lifted motherboard.
    • Remove the keypad from the assembly.
Conclusión
Elizabeth Kelly
Miembro Desde 10/22/12
501 Reputación
5 Guías creadas
Equipo
Clemson, Team 15-1, Benson Fall 2012 Miembro de Clemson, Team 15-1, Benson Fall 2012
CLEM-BENSON-F12S15G1
4 Miembros
10 Guías creadas
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 4
Ultimos 30 días: 20
Todo El Tiempo: 966
