Introducción
In many devices such as handheld phones, the buttons necessary to operate the device will malfunction. This guide will show you how to access the rubber keypad in a step-by-step manner in order to determine what is malfunctioning with the keypad. If the keypad is damaged, this guide will show you how to remove the keypad from the housing.
Partes
No se requieren partes.
  1. Orient the phone so that the phone model and other descriptive information is facing upward. Locate the two silver screws near the hinge where the battery is housed.
    • Orient the phone so that the phone model and other descriptive information is facing upward.
    • Locate the two silver screws near the hinge where the battery is housed.
    • Remove the silver screws using a Phillips head #2 screwdriver.
  2. Pull off the back panel of the phone. Make sure you pull the cover off carefully in order to prevent damage to the back cover. Make sure you pull the cover off carefully in order to prevent damage to the back cover.
    • Pull off the back panel of the phone.
    • Make sure you pull the cover off carefully in order to prevent damage to the back cover.
  3. ¡Envío gratuito para todos los pedidos de más de USD100.00 o que contengan un Pro Tech Toolkit!
    Visita Nuestra Tienda
  4. Locate and unscrew the circled screw using a Philips head #2 screw driver or screw driver head. Locate and unscrew the circled screw using a Philips head #2 screw driver or screw driver head.
    • Locate and unscrew the circled screw using a Philips head #2 screw driver or screw driver head.
  5. Lift the motherboard away from the phone housing.
    • Lift the motherboard away from the phone housing.
    • Be careful when lifting the motherboard. To prevent damage to the motherboard, gradually lift it from its place in the assembly.
  6. Now that the motherboard has been lifted out of place, the keypad can be accessed. Using your fingers push the buttons from the the phone toward the lifted motherboard.
    • Now that the motherboard has been lifted out of place, the keypad can be accessed.
    • Using your fingers push the buttons from the the phone toward the lifted motherboard.
    • Remove the keypad from the assembly.
Conclusión
Elizabeth Kelly
Miembro Desde 22/10/12
501 Reputación
5 Guías creadas
Equipo
Clemson, Team 15-1, Benson Fall 2012 Miembro de Clemson, Team 15-1, Benson Fall 2012
CLEM-BENSON-F12S15G1
4 Miembros
10 Guías creadas
Ver Estadísticas:
Ultimas 24 Horas: 0
Últimos 7 Días: 1
Últimos 30 Días: 3
Todo El Tiempo: 397
