Introducción
Después de quitar la cubierta, quitar la rueda de desplazamiento permitirá el acceso a los resortes y a la rueda misma.
Qué necesitas
Sostén el mouse para que la parte inferior quede hacia arriba.
Retira el único tornillo Phillips n.° 1 de la mitad inferior del mouse.
Ubica la rueda de desplazamiento en el mouse.
Coge la rueda de desplazamiento con el pulgar y el índice.
Levántala suavemente para quitar la rueda de desplazamiento del mouse.
Para volver a armar tu dispositivo, sigue estas instrucciones en orden inverso.
5 personas más completaron esta guía.
Un agradecimiento especial a estos traductores:
100%
¡ Francisco Javier Saiz Esteban nos está ayudando a reparar el mundo! ¿Quieres contribuir?
Empezar a traducir ›
2 comentarios
Thanks! The picture was what I needed after the mouse wheel parts came apart. My mouse is an M-BT58, but based on the numbers on the circuit board, there are probably several that are essentially the same. For others, here are some more details on putting things back together.
The mouse wheel has 4 parts:
1) The wheel itself (really a rubber tire and plastic rim, but they stay together)
2) Plastic carrier for the wheel
3) A spring for controlling rotation of the scroll wheel. This spring is at the top of the picture shown.
4) A spring for controlling clicks of the scroll wheel, shown near the wire leading to the computer.
Reassembly
1) Put spring (3) on carrier (2). There is a hole where the very tip of the end without the loop fits in.
2) Push the shorter axle of the mouse wheel into the carrier slightly depressing spring (3) as it is inserted. Once the wheel is inserted, the spring will stay in place.
3) Put spring (4) on the longer axle of the mouse wheel.
4) Install the carrier into the base of the mouse.
