Saltar al contenido principal
Removing the HP Elitebook 6930p Switch Cover
Qué necesitas
  1. Removing the HP Elitebook 6930p Switch Cover, Battery Removal: paso 1, imagen 1 de 3 Removing the HP Elitebook 6930p Switch Cover, Battery Removal: paso 1, imagen 2 de 3 Removing the HP Elitebook 6930p Switch Cover, Battery Removal: paso 1, imagen 3 de 3
    • Flip laptop over and locate the battery release button
    • Push release button to the left to release battery and gently pull battery from the laptop
  2. Removing the HP Elitebook 6930p Switch Cover, Keyboard: paso 2, imagen 1 de 3 Removing the HP Elitebook 6930p Switch Cover, Keyboard: paso 2, imagen 2 de 3 Removing the HP Elitebook 6930p Switch Cover, Keyboard: paso 2, imagen 3 de 3
    • Loosen the three Phillips 2.5×9.0 captive screws that secure the keyboard to the laptop
    • Turn the laptop so the keyboard is facing up and locate the 4 retention tabs along the back edge of the keyboard
    • Slide the retention clips toward the keyboard to release the keyboard
  3. Removing the HP Elitebook 6930p Switch Cover: paso 3, imagen 1 de 3 Removing the HP Elitebook 6930p Switch Cover: paso 3, imagen 2 de 3 Removing the HP Elitebook 6930p Switch Cover: paso 3, imagen 3 de 3
    • Use a plastic pry tool to lift the rear edge of the keyboard.
    • Pull the keyboard slightly towards the display to disengage the tabs along the front of the keyboard from the laptop palm rest.
    • Lift the keyboard up to reveal the ribbon connectors
  4. Removing the HP Elitebook 6930p Switch Cover: paso 4, imagen 1 de 3 Removing the HP Elitebook 6930p Switch Cover: paso 4, imagen 2 de 3 Removing the HP Elitebook 6930p Switch Cover: paso 4, imagen 3 de 3
    • Release the larger ribbon cable by flipping the brown retainer up so it is parallel with the ribbon cable
    • Release the smaller ribbon cable by lifting up the white retainer
    • I found it easier to reinstall both cables with the new keyboard resting on the back edge
  5. Removing the HP Elitebook 6930p Switch Cover, Switch Cover: paso 5, imagen 1 de 3 Removing the HP Elitebook 6930p Switch Cover, Switch Cover: paso 5, imagen 2 de 3 Removing the HP Elitebook 6930p Switch Cover, Switch Cover: paso 5, imagen 3 de 3
    • Remove the two M2.0×4.0 broad-head screws.
    • Remove the three Torx T8 M2.5×7.0 screws.
  6. Removing the HP Elitebook 6930p Switch Cover: paso 6, imagen 1 de 3 Removing the HP Elitebook 6930p Switch Cover: paso 6, imagen 2 de 3 Removing the HP Elitebook 6930p Switch Cover: paso 6, imagen 3 de 3
    • Turn the computer over with the front toward you and the open the computer as far as possible.
    • Release the ZIF connector for the power button board cable.
    • Remove the switch cover by lifting it straight up and flip it forward.
    • Release the ZIF connector for the LED board cable.
Conclusión
4 personas más completaron esta guía.
Richdave
Miembro Desde 04/09/10
32,051 Reputación
30 Guías creadas
Equipo
Master Techs Miembro de Master Techs
Community
322 Miembros
2,519 Guías creadas
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 1
Ultimos 30 días: 6
Todo El Tiempo: 1,946
