Saltar al contenido principal
Repara tus cosas
Derecho a reparar
Partes y herramientas
Introducción
This guide shows how to remove the laptop HDD
Partes
No se especificaron partes.
  1. Flip laptop over and locate the battery release button Push release button to the left to release battery and gently pull battery from the laptop Push release button to the left to release battery and gently pull battery from the laptop
    • Flip laptop over and locate the battery release button
    • Push release button to the left to release battery and gently pull battery from the laptop
  2. Kits de Reparación de Pantalla LCD de iPhone
    La opción de presupuesto, cubierta por nuestra garantía de por vida.
    Compra kits
    Reduce los costos de reparación, no la calidad.
    Compra kits
  3. With the bottom of the laptop facing up and the front toward you locate and loosen the two M2.0×5.0 captive screws holding the hard drive bay cover closed. Lift the left side of the bay cover and swing it up and to the right to remove it. Loosen the M2.5×10.0 captive screw that holds the hard drive in.
    • With the bottom of the laptop facing up and the front toward you locate and loosen the two M2.0×5.0 captive screws holding the hard drive bay cover closed.
    • Lift the left side of the bay cover and swing it up and to the right to remove it.
    • Loosen the M2.5×10.0 captive screw that holds the hard drive in.
    • Grasp the plastic tab and slide the hard drive to the right to disconnect it from the motherboard.
    • Lift the hard drive straight up and out of the laptop.
  4. To remove the hard drive from the bracket remove the two M3.0×4.0 screws from each side of the hard drive. To remove the hard drive from the bracket remove the two M3.0×4.0 screws from each side of the hard drive.
    • To remove the hard drive from the bracket remove the two M3.0×4.0 screws from each side of the hard drive.
Conclusión
14 personas más completaron esta guía.
Richdave
Miembro Desde 09/04/10
30,091 Reputación
30 Guías creadas
Equipo
Master Techs Miembro de Master Techs
Community
293 Miembros
841 Guías creadas
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 12
Ultimos 30 días: 48
Todo El Tiempo: 7,698
