Saltar al contenido principal
Repara tus cosas
Derecho a reparar
Partes y herramientas
Introducción
This guide will show you how to remove the display assembly from the laptop
  1. Flip laptop over and locate the battery release button Push release button to the left to release battery and gently pull battery from the laptop Push release button to the left to release battery and gently pull battery from the laptop
    • Flip laptop over and locate the battery release button
    • Push release button to the left to release battery and gently pull battery from the laptop
  2. Loosen the three Phillips 2.5×9.0 captive screws that secure the keyboard to the laptop Turn the laptop so the keyboard is facing up and locate the 4 retention tabs along the back edge of the keyboard Slide the retention clips toward the keyboard to release the keyboard
    • Loosen the three Phillips 2.5×9.0 captive screws that secure the keyboard to the laptop
    • Turn the laptop so the keyboard is facing up and locate the 4 retention tabs along the back edge of the keyboard
    • Slide the retention clips toward the keyboard to release the keyboard
  3. Use a plastic pry tool to lift the rear edge of the keyboard. Pull  the keyboard slightly towards the display to disengage  the tabs along the front of the keyboard from the laptop palm rest. Lift the keyboard up to reveal the ribbon connectors
    • Use a plastic pry tool to lift the rear edge of the keyboard.
    • Pull the keyboard slightly towards the display to disengage the tabs along the front of the keyboard from the laptop palm rest.
    • Lift the keyboard up to reveal the ribbon connectors
  4. Release the larger ribbon cable by flipping the brown retainer up so it is parallel with the ribbon cable Release the smaller ribbon cable by lifting up the white retainer I found it easier to reinstall both cables with the new keyboard resting on the back edge
    • Release the larger ribbon cable by flipping the brown retainer up so it is parallel with the ribbon cable
    • Release the smaller ribbon cable by lifting up the white retainer
    • I found it easier to reinstall both cables with the new keyboard resting on the back edge
  5. Kits de Reparación de Pantalla LCD de iPhone
    La opción de presupuesto, cubierta por nuestra garantía de por vida.
    Compra kits
    Reduce los costos de reparación, no la calidad.
    Compra kits
  6. Remove the two M2.0×4.0 broad-head screws. Remove the three Torx T8 M2.5×7.0 screws. Remove the three Torx T8 M2.5×7.0 screws.
    • Remove the two M2.0×4.0 broad-head screws.
    • Remove the three Torx T8 M2.5×7.0 screws.
  7. Turn the computer over with the front toward you and the open the computer as far as possible. Release the ZIF connector for the power button board cable. Remove the switch cover by lifting it straight up and flip it forward.
    • Turn the computer over with the front toward you and the open the computer as far as possible.
    • Release the ZIF connector for the power button board cable.
    • Remove the switch cover by lifting it straight up and flip it forward.
    • Release the ZIF connector for the LED board cable.
  8. Close the lid and turn the laptop so the rear is facing you Locate and remove the two Torx T8 2.5×7.0 screws at each corner
    • Close the lid and turn the laptop so the rear is facing you
    • Locate and remove the two Torx T8 2.5×7.0 screws at each corner
    • The screws may have rubber caps over them. If so remove with a spudger or similar tool.
  9. With the laptop upside down, locate and remove the two Torx T8 2.5×7.0 screws. The screws may have rubber caps over them.  If so remove with a spudger or similar tool.
    • With the laptop upside down, locate and remove the two Torx T8 2.5×7.0 screws.
  10. Turn the computer right-side up with the front toward you and open the computer lid past 90 degrees. Locate and disconnect the display panel cable. Locate and disconnect the microphone cable.
    • Turn the computer right-side up with the front toward you and open the computer lid past 90 degrees.
    • Locate and disconnect the display panel cable.
    • Locate and disconnect the microphone cable.
    • Locate and disconnect the webcam cable.
    • Locate and disconnect the 3 antenna cables.
    • Unclip the antenna cables from the retaining clips.
    • NOTE There are 2 antenna cables that go from the display assembly through the hole shown and connect to the WWAN (3G) WiFi card if it is installed. In my case they were just threaded into the hole to make things tidy as I didn't have a WWAN card.
  11. The display assembly will be unsupported when the following screws are removed.  To prevent damage support the display before removing the screws. Remove the two T8 2.5×7.0 screws holding the display assembly to the laptop.
    • The display assembly will be unsupported when the following screws are removed. To prevent damage support the display before removing the screws.
    • Remove the two T8 2.5×7.0 screws holding the display assembly to the laptop.
    • Lift the display assembly straight up to remove it from the laptop.
Conclusión
11 personas más completaron esta guía.
Richdave
Miembro Desde 09/04/10
30,091 Reputación
30 Guías creadas
Equipo
Master Techs Miembro de Master Techs
Community
293 Miembros
841 Guías creadas
muy útil el aporte
Emilio Zelaya - Contestar
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 20
Ultimos 30 días: 82
Todo El Tiempo: 13,745
