Introducción
This guide will show you how to remove the optical (cd) drive from your HP Compaq dx2000MT.
Partes
No se requieren partes.
Turn off your computer and remove the power cable by pulling it straight out of its socket.
  • Turn off your computer and remove the power cable by pulling it straight out of its socket.
Agregar Comentario
Remove the 2 Phillips #2 screws that secure the case door to the device. Remove the 2 Phillips #2 screws that secure the case door to the device.
  • Remove the 2 Phillips #2 screws that secure the case door to the device.
Agregar Comentario
Remove the side case door by pushing towards the rear of the device with your hand. This may take considerable force so keep pushing! Once you slide the door back, remove it by pulling it outwards from the device.
  • Remove the side case door by pushing towards the rear of the device with your hand.
    • This may take considerable force so keep pushing!
  • Once you slide the door back, remove it by pulling it outwards from the device.
Agregar Comentario
Remove the side case door by pushing towards the rear of the device with your hand. Once again, this may take considerable force. Once you slide the door back, remove it by pulling it outwards from the device.
    • Once again, this may take considerable force.
Agregar Comentario
Remove the IDE data cable and the power cable from the optical drive by pulling away from the drive. Remove the IDE data cable and the power cable from the optical drive by pulling away from the drive. Remove the IDE data cable and the power cable from the optical drive by pulling away from the drive.
  • Remove the IDE data cable and the power cable from the optical drive by pulling away from the drive.
Agregar Comentario
Remove the 2 Torx T15 screws holding the optical drive in place. Remove the 2 Torx T15 screws holding the optical drive in place.
  • Remove the 2 Torx T15 screws holding the optical drive in place.
Agregar Comentario
Remove the other 2 Torx T15 screws holding the other side of the drive in place. Remove the other 2 Torx T15 screws holding the other side of the drive in place.
  • Remove the other 2 Torx T15 screws holding the other side of the drive in place.
Agregar Comentario
Remove the optical drive by sliding it out the front of the device. Remove the optical drive by sliding it out the front of the device. Remove the optical drive by sliding it out the front of the device.
  • Remove the optical drive by sliding it out the front of the device.
Agregar Comentario
Conclusión
Logan Pace
Miembro Desde 12/10/11
2,020 Reputación
15 Guías creadas
Equipo
Cal Poly, Team 17-16, Regan Fall 2011 Miembro de Cal Poly, Team 17-16, Regan Fall 2011
CPSU-REGAN-F11S17G16
4 Miembros
17 Guías creadas
Agregar Comentario
Ver Estadísticas:
Ultimas 24 Horas: 0
Últimos 7 Días: 0
Últimos 30 Días: 4
Todo El Tiempo: 1,132
