Partes
No se requieren partes.
  1. Place the laptop upside down on a clean, flat surface. Locate the battery release button with the padlock symbol above it. Slide the battery release button towards the padlock symbol and hold it there.  Note that the button is spring loaded and will return if released.
    • Place the laptop upside down on a clean, flat surface.
    • Locate the battery release button with the padlock symbol above it.
    • Slide the battery release button towards the padlock symbol and hold it there. Note that the button is spring loaded and will return if released.
      • The battery is now released from the battery compartment.
    • Gently remove the battery from the side of the laptop.
  2. Turn the laptop upside down and locate the panel labeled C Unscrew the single screw holding the cover in place. Lift up the cover and remove it to expose the Modem Card.
    • Turn the laptop upside down and locate the panel labeled C
    • Unscrew the single screw holding the cover in place.
    • Lift up the cover and remove it to expose the Modem Card.
  3. ¡Envío gratuito para todos los pedidos de más de USD100.00 o que contengan un Pro Tech Toolkit!
    Visita Nuestra Tienda
    ¿Alguna vez arreglaste algo? Eso es genial.
    Comparte tu historia de reparación con #SoyUnGenio
    Todos somos Genios
  4. Locate the Modem card. Remove the screws.
    • Locate the Modem card.
    • Remove the screws.
  5. Pull tab to lift the card out of the connector on the main board. Disconnect the cable attached to the left edge of the Modem card
    • Pull tab to lift the card out of the connector on the main board.
    • Disconnect the cable attached to the left edge of the Modem card
Linea de Meta
Lauren
Miembro Desde 25/04/10
4 Reputación
2 Guías creadas
Equipo
Cal Poly, Team 16-2, Maness Spring 2010 Miembro de Cal Poly, Team 16-2, Maness Spring 2010
CPSU-MANESS-S10S16G2
4 Miembros
9 Guías creadas
Ver Estadísticas:
Ultimas 24 Horas: 0
Últimos 7 Días: 1
Últimos 30 Días: 2
Todo El Tiempo: 4,358
