Introducción
Learn how to get to the interior of a Logitech Webcam Pro 9000. There are a few extra wires, so be careful not to pull the covers apart too quickly.
Partes
No se requieren partes.
  1. Remove the two 8mm Phillips#0 screws on the back cover. The motherboard is attaching the two covers together, so don't separate them entirely just yet.
    • Remove the two 8mm Phillips#0 screws on the back cover.
    • The motherboard is attaching the two covers together, so don't separate them entirely just yet.
    • There is a button that loosens as the Phillips screws are removed. Don't be alarmed if it falls out.
  2. ¡Envío gratuito para todos los pedidos de más de USD100 o que contengan un Pro Tech Toolkit!
    Visita Nuestra Tienda
  3. Remove the four 6mm Phillips#0 screws  connecting the motherboard and front cover. DO NOT detach the wire connecting the motherboard to the front cover.
    • Remove the four 6mm Phillips#0 screws connecting the motherboard and front cover.
    • DO NOT detach the wire connecting the motherboard to the front cover.
Conclusión
Equipo
Cal Poly, Team 12-34, Amido Spring 2013 Miembro de Cal Poly, Team 12-34, Amido Spring 2013
CPSU-AMIDO-S13S12G34
4 Miembros
8 Guías creadas
Agregar Comentario
Ver Estadísticas:
Ultimas 24 Horas: 1
Últimos 7 Días: 1
Últimos 30 Días: 6
Todo El Tiempo: 771
