Saltar al contenido principal
Removing the Cover From the Printer
Sólo Prerrequisito
Esta guía solo debería usarse como prerrequisito para otras guías. Por tanto, estará incompleta.
Qué necesitas
  1. Removing the Cover From the Printer, Top Cover: paso 1, imagen 1 de 1
    • Remove the back two 14.0 mm Torx #10 screws.
  2. Removing the Cover From the Printer: paso 2, imagen 1 de 1
    • Lay the printer on its back.
    • Grab the paper tray by its right side and pull it to the left and up.
  3. Removing the Cover From the Printer: paso 3, imagen 1 de 1
    • Open the frontal access panel by lifting it from the top.
    • Similar to the paper tray, grab it from the right side and pull it to the left and up.
  4. Removing the Cover From the Printer: paso 4, imagen 1 de 3 Removing the Cover From the Printer: paso 4, imagen 2 de 3 Removing the Cover From the Printer: paso 4, imagen 3 de 3
    • Take out the two frontal 14.0 mm Torx #10 screws.
    • Carefully lift the frontal cover.
    • Don't lift it up aggressively. A strip will be attached to it.
Conclusión
Equipo
Cal Poly, Team 1-41, Maness Winter 2014 Miembro de Cal Poly, Team 1-41, Maness Winter 2014
CPSU-MANESS-W14S1G41
4 Miembros
14 Guías creadas
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 0
Ultimos 30 días: 0
Todo El Tiempo: 29
