Saltar al contenido principal
Removing the Back Panel
Qué necesitas
  1. Removing the Back Panel, Removing the Back Panel: paso 1, imagen 1 de 3 Removing the Back Panel, Removing the Back Panel: paso 1, imagen 2 de 3 Removing the Back Panel, Removing the Back Panel: paso 1, imagen 3 de 3
    Herramienta utilizada en este paso:
    Comprar
    • Place the tablet face down on a soft, stable surface that will protect the screen.
    • Next, Scrape off the seal over the screw in the back of the tablet with a Metal Spudger.
    • Use the Phillips #000 Screwdriver to remove the M1.4 × 2.5 screw.
    • If the seal covering the screw has already been removed, please proceed to the next step in the process.
    • As the screw is small, you may wish to extract it using a pair of tweezers.
  2. Removing the Back Panel: paso 2, imagen 1 de 3 Removing the Back Panel: paso 2, imagen 2 de 3 Removing the Back Panel: paso 2, imagen 3 de 3
    • Starting on the side, work your way around the the tablet to pop off the back cover. You will want to utilize a metal Spudger for this.
    • Some force may be required initially to pry the back cover off.
    • Note that the button tabs for this device are loose inside the case and will fall out when opening.
Conclusión
4 personas más completaron esta guía.
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 2
Ultimos 30 días: 14
Todo El Tiempo: 2,506
