Introducción
This guide will help you to repair and install a new grinder in your Jura Impressa F50 coffee machine.
Qué necesitas
Remove the lock washer on the axle for grinding degree adjustment using pliers.
Need help closing the case of your Jura Impressa F50 coffee grinder? Check out the instructions "Close machine housing".
3 personas más completaron esta guía.
Un agradecimiento especial a estos traductores:
100%
Estos traductores nos están ayudando a reparar el mundo! ¿Quieres contribuir?
Empezar a traducir ›
Un comentario
I’ve got a similar Impressa machine to this one (the outside is visually identical). While removing the grinder, the ferrite inductor that is on the black wiring going into the grinder broke. Does anyone know what the rating/specs are of this inductor so I can splice in a replacement? The other similar inductor in the machine is unmarked and offers no hint as to what it’s ratings are. It’s been weeks since I broke the piece and I’m having a lot of trouble figuring this out.
