Saltar al contenido principal
Removing Texas Instruments TI-92 Back Cover
  1. Removing Texas Instruments TI-92 Back Cover, Back Cover: paso 1, imagen 1 de 3 Removing Texas Instruments TI-92 Back Cover, Back Cover: paso 1, imagen 2 de 3 Removing Texas Instruments TI-92 Back Cover, Back Cover: paso 1, imagen 3 de 3
    • The first step to any repair operation is to remove the front cover.
    • Grab the back of the calculator with one hand and the cover with the other.
    • Pull the cover off from one of the sides for easy removal.
  2. Removing Texas Instruments TI-92 Back Cover: paso 2, imagen 1 de 2 Removing Texas Instruments TI-92 Back Cover: paso 2, imagen 2 de 2
    • Orientate the calculator with the top facing towards you.
    • Slide the locking tab,found on the top part of the calculator, to the unlock position.
  3. Removing Texas Instruments TI-92 Back Cover: paso 3, imagen 1 de 2 Removing Texas Instruments TI-92 Back Cover: paso 3, imagen 2 de 2
    • "Locking Tab"
    • To remove the back cover, slide the cover away from the locking tab towards the bottom of the calculator until the cover no longer slides.
    • Then with the front of the calculator facing down, pull up on the back cover.
    • The calculator should now be orientated with the front facing down, as shown in picture 2.
Conclusión
Equipo
Cal Poly, Team 15-51, Garner Spring 2010 Miembro de Cal Poly, Team 15-51, Garner Spring 2010
CPSU-GARNER-S10S15G51
5 Miembros
9 Guías creadas
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 4
Ultimos 7 días: 15
Ultimos 30 días: 32
Todo El Tiempo: 3,310
