Saltar al contenido principal
Repara tus cosas
Derecho a reparar
Tienda
Partes
No se especificaron partes.
  1. Place the plastic opening tool in the bottom corner of the phone in the crevice between the flap to remove the cover.
    • Place the plastic opening tool in the bottom corner of the phone in the crevice between the flap to remove the cover.
  2. Remove the cover with  a slight twisting motion. This is what the phone will look like after the cover is removed.
    • Remove the cover with a slight twisting motion. This is what the phone will look like after the cover is removed.
  3. To replace the flip cover, repeat removal steps in the opposite order; be sure to connect the new cover by matching the square side of the cover to the square side of the phone base and the circle side of the cover to the circle side of the phone base. To replace the flip cover, repeat removal steps in the opposite order; be sure to connect the new cover by matching the square side of the cover to the square side of the phone base and the circle side of the cover to the circle side of the phone base.
    • To replace the flip cover, repeat removal steps in the opposite order; be sure to connect the new cover by matching the square side of the cover to the square side of the phone base and the circle side of the cover to the circle side of the phone base.
Conclusión
Una persona más ha completado esta guía.
manning
Miembro Desde 12/03/12
21 Reputación
1 Guía escrita
Equipo
Clemson, Team 1-4, Benson Spring 2012 Miembro de Clemson, Team 1-4, Benson Spring 2012
CLEM-BENSON-S12S1G4
4 Miembros
14 Guías creadas
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 0
Ultimos 30 días: 2
Todo El Tiempo: 1,749
