Saltar al contenido principal
Introducción
This guide will show how to remove the printer's rear casing to access the interior of the machine.
Partes
No se especificaron partes.
  1. Remove the hinged top panel by taking the small pins at the bottom of the panel out of their holes. Remove the hinged top panel by taking the small pins at the bottom of the panel out of their holes. Remove the hinged top panel by taking the small pins at the bottom of the panel out of their holes.
    • Remove the hinged top panel by taking the small pins at the bottom of the panel out of their holes.
  2. Kits de Reparación de Batería de iPhone
    Sólo $29.99
    Buy Now
    Sólo $29.99
    Buy Now
  3. Using a Phillips #2 screwdriver, remove the four 1" long, Phillips, PH#2  screws on the back of the printer.
    • Using a Phillips #2 screwdriver, remove the four 1" long, Phillips, PH#2 screws on the back of the printer.
  4. Gently lift the top panel while simultaneously pulling off the back panel. Before pulling out the back panel entirely, make sure to remove the rear cooling fan from its slot. Before pulling out the back panel entirely, make sure to remove the rear cooling fan from its slot.
    • Gently lift the top panel while simultaneously pulling off the back panel.
    • Before pulling out the back panel entirely, make sure to remove the rear cooling fan from its slot.
Conclusión
4 personas más completaron esta guía.
bbaustin
Miembro Desde 12/10/11
199 Reputación
6 Guías creadas
Equipo
Cal Poly, Team 17-18, Regan Fall 2011 Miembro de Cal Poly, Team 17-18, Regan Fall 2011
CPSU-REGAN-F11S17G18
4 Miembros
6 Guías creadas
Very easy to follow. I think I would have broken something if I had not followed these simple steps.
rob - Contestar
Thank you on how to do this. A little force is required to lift the top cover edges one by one to get the back cover off, but it does come off, without taking the top cover off. I think my solenoid is bad, as the printer takes two sheets of paper initially and then more right afterwards. The rubber pick up wheel seems to be fine after cleaning, as it picks up the paper without issue, just multiple sheets is all.
kirkdcharles - Contestar
Thanks. I would have broken the top cover or back panel if I did not read your post. It take a little force to pull the back cover off while applying upward pressure to the top cover ends, one at a time. I think I have to replace the solenoid as the rubber pick up wheel pulls the paper up fine, but multiple sheets after the first rotation of the wheel.
Agregar Comentario
Ver Estadísticas:
Ultimas 24 Horas: 0
Últimos 7 Días: 5
Últimos 30 Días: 11
Todo El Tiempo: 5,063
