Saltar al contenido principal
Removing PowerMac G4 M5183 DVD-ROM Drive Tray
Qué necesitas
  1. Removing PowerMac G4 M5183 DVD-ROM Drive Tray, Opening PowerMac G4 M5183 Case: paso 1, imagen 1 de 2 Removing PowerMac G4 M5183 DVD-ROM Drive Tray, Opening PowerMac G4 M5183 Case: paso 1, imagen 2 de 2
    • Pull on outer latch.
    • Lower door until it is level with your work surface.
    • Before working on the computer make sure it is not plugged into a power supply, then touch a metal object. This discharges static electricity, which could damage the computer.
  2. Removing PowerMac G4 M5183 DVD-ROM Drive Tray, DVD-ROM Drive: paso 2, imagen 1 de 2 Removing PowerMac G4 M5183 DVD-ROM Drive Tray, DVD-ROM Drive: paso 2, imagen 2 de 2
    • Removing the faceplate.
    • On the inside of the case, find the two plastic tabs.
    • While depressing the tabs, remove the faceplate by pulling and rotating outward.
  3. Removing PowerMac G4 M5183 DVD-ROM Drive Tray: paso 3, imagen 1 de 1
    • Remove the two screws on the front of the drive with the Phillips #1 screwdriver.
  4. Removing PowerMac G4 M5183 DVD-ROM Drive Tray: paso 4, imagen 1 de 3 Removing PowerMac G4 M5183 DVD-ROM Drive Tray: paso 4, imagen 2 de 3 Removing PowerMac G4 M5183 DVD-ROM Drive Tray: paso 4, imagen 3 de 3
    • Pull the drive out to allow access to the power and ribbon cables. Do not fully remove.
    • Remove both the power and ribbon cable.
Linea de Meta
26 personas más completaron esta guía.
Justin Petrilli
Miembro Desde 01/21/10
3,114 Reputación
11 Guías creadas
Equipo
Cal Poly, Team 13-24, Maness Winter 2010 Miembro de Cal Poly, Team 13-24, Maness Winter 2010
CPSU-MANESS-W10S13G24
4 Miembros
25 Guías creadas
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 13
Ultimos 30 días: 35
Todo El Tiempo: 10,519
