Saltar al contenido principal
Removing Olympus FE-210 Rear Casing
Qué necesitas
  1. Removing Olympus FE-210 Rear Casing, Battery: paso 1, imagen 1 de 2 Removing Olympus FE-210 Rear Casing, Battery: paso 1, imagen 2 de 2
    • The battery compartment is located on the bottom side of the camera. Push the button in, and slide the cover to get access to the batteries.
  2. Removing Olympus FE-210 Rear Casing: paso 2, imagen 1 de 2 Removing Olympus FE-210 Rear Casing: paso 2, imagen 2 de 2
    • The batteries will slide right out.
    • When putting new batteries in, make sure they are pointing the right direction.
  3. Removing Olympus FE-210 Rear Casing, Front Casing: paso 3, imagen 1 de 3 Removing Olympus FE-210 Rear Casing, Front Casing: paso 3, imagen 2 de 3 Removing Olympus FE-210 Rear Casing, Front Casing: paso 3, imagen 3 de 3
    • Remove the 7 screws holding the front case in place, with a #00 screwdriver.
    • Six screws are 3.6 mm.
    • The seventh screw is 3.2 mm.
  4. Removing Olympus FE-210 Rear Casing: paso 4, imagen 1 de 3 Removing Olympus FE-210 Rear Casing: paso 4, imagen 2 de 3 Removing Olympus FE-210 Rear Casing: paso 4, imagen 3 de 3
    • Pulling the front case off, requires applying enough strength in the right areas.
    • The front case snaps into place in three places:
    • At the top and bottom of the battery side (opposite of side pictured) of the case.
    • Right in the middle of the DC-in side (side pictured) of the case.
    • Top of the camera, to the left of the power button.
    • Once those places are disconnected, the front case will pop right off.
    • The camera in the first two pictures is upside down. This is the best position to place your thumbs to remove the case.
  5. Removing Olympus FE-210 Rear Casing, Rear Casing: paso 5, imagen 1 de 1
    • Remove the 3.2 mm screw in the battery compartment using a #00 screwdriver.
    • After removal of the screw the case will be loose, but do not tug it off. There is a cord connecting the rear controls to the motherboard.
  6. Removing Olympus FE-210 Rear Casing: paso 6, imagen 1 de 3 Removing Olympus FE-210 Rear Casing: paso 6, imagen 2 de 3 Removing Olympus FE-210 Rear Casing: paso 6, imagen 3 de 3
    • Carefully pull the rear case away from the camera until you have access to the cord connected to the motherboard.
    • Lift the white latch using a fingernail or a spudger.
    • Pull the cord from its connector.
Conclusión
Una persona más ha completado esta guía.
Matt
Miembro Desde 01/25/11
811 Reputación
6 Guías creadas
Equipo
Cal Poly, Team 4-36, Regan Winter 2011 Miembro de Cal Poly, Team 4-36, Regan Winter 2011
CPSU-REGAN-W11S4G36
3 Miembros
14 Guías creadas
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 3
Ultimos 30 días: 18
Todo El Tiempo: 2,596
