Introducción
Step-by-step guide to removing your phone's antenna.
  1. The antenna is located on top right corner of the phone while the front of the phone is facing you. Unscrew the antenna clockwise until it is loose enough to remove from the phone. Unscrew the antenna clockwise until it is loose enough to remove from the phone.
    • The antenna is located on top right corner of the phone while the front of the phone is facing you.
    • Unscrew the antenna clockwise until it is loose enough to remove from the phone.
  2. ¡Envío gratuito para todos los pedidos de más de USD100.00 o que contengan un Pro Tech Toolkit!
    Visita Nuestra Tienda
Conclusión
Equipo
Cal Poly, Team 30-40, Garner Spring 2010 Miembro de Cal Poly, Team 30-40, Garner Spring 2010
CPSU-GARNER-S10S30G40
4 Miembros
14 Guías creadas
Ver Estadísticas:
Ultimas 24 Horas: 0
Últimos 7 Días: 3
Últimos 30 Días: 9
Todo El Tiempo: 2,915
