Saltar al contenido principal
Introducción
This is a very simple task, only requiring a screwdriver.
Partes
No se especificaron partes.
  1. Lift up the winding lever and rotate it clockwise to open the back film compartment. Lift up the winding lever and rotate it clockwise to open the back film compartment.
    • Lift up the winding lever and rotate it clockwise to open the back film compartment.
  2. Kits de Reparación de Batería de MacBook Air
    A partir de $69.99
    Buy Now
    A partir de $69.99
    Buy Now
  3. Lift up the winding handle and remove one 3.85mm screw. Remove the film winding handle.
    • Lift up the winding handle and remove one 3.85mm screw.
    • Remove the film winding handle.
  4. Pull the film winder down until it comes free. Do not close the film compartment. The compartment will not open without the film winding lever installed properly.
    • Pull the film winder down until it comes free.
    • Do not close the film compartment. The compartment will not open without the film winding lever installed properly.
Conclusión
Una persona más ha completado esta guía.
Nick
Miembro Desde 19/04/11
411 Reputación
4 Guías creadas
Equipo
Cal Poly, Team 8-7, Regan Spring 2011 Miembro de Cal Poly, Team 8-7, Regan Spring 2011
CPSU-REGAN-S11S8G7
4 Miembros
4 Guías creadas
Agregar Comentario
Ver Estadísticas:
Ultimas 24 Horas: 0
Últimos 7 Días: 9
Últimos 30 Días: 42
Todo El Tiempo: 10,393
