Saltar al contenido principal
Removing Minolta X-370 Bottom Cover
Qué necesitas
  1. Removing Minolta X-370 Bottom Cover, Minolta X-370 Battery Replacement: paso 1, imagen 1 de 2 Removing Minolta X-370 Bottom Cover, Minolta X-370 Battery Replacement: paso 1, imagen 2 de 2
    • Flip the camera so that the bottom is facing you.
    • Take a spare coin and unscrew the battery cover off.
  2. Removing Minolta X-370 Bottom Cover: paso 2, imagen 1 de 1
    • Remove the batteries, making sure to note their proper alignment.
  3. Removing Minolta X-370 Bottom Cover, Bottom Cover: paso 3, imagen 1 de 2 Removing Minolta X-370 Bottom Cover, Bottom Cover: paso 3, imagen 2 de 2
    • Remove two 4.8mm screws.
    • Remove one 3.4mm screw.
    • Remove one 2.65mm screw.
    • Lift off the back cover.
  4. Removing Minolta X-370 Bottom Cover: paso 4, imagen 1 de 1
    • Remove three 3.5mm screws.
    • Remove two 3.8mm screws.
    • Remove one 6.35mm screw.
    • Remove one 4mm screw. Lift off the disk.
    • Remove one 5.11mm screw.
  5. Removing Minolta X-370 Bottom Cover: paso 5, imagen 1 de 1
    • Lift up the silver, metal piece
    • Please note that some internal pieces may come loose during this process.
Conclusión
3 personas más completaron esta guía.
Nick
Miembro Desde 04/19/11
525 Reputación
4 Guías creadas
Equipo
Cal Poly, Team 8-7, Regan Spring 2011 Miembro de Cal Poly, Team 8-7, Regan Spring 2011
CPSU-REGAN-S11S8G7
4 Miembros
8 Guías creadas
Un comentario
good advice, will use, have multiple Minolta cameras to work with.
gabriel johnson - Contestar
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 1
Ultimos 7 días: 5
Ultimos 30 días: 24
Todo El Tiempo: 10,756
