Saltar al contenido principal
Fix Your Stuff
Right to Repair
Parts & Tools
Introducción
After you remove the back cover, you can get to any part of your RoadMate.
Partes
No se especificaron partes.
  1. Remove 4 rubber caps covering each screw by inserting the screwdriver into the side of cap and prying back and forth. Please note: this is a tedious process, but be patient.
    • Remove 4 rubber caps covering each screw by inserting the screwdriver into the side of cap and prying back and forth.
    • Please note: this is a tedious process, but be patient.
  2. Remove the 4 screws holding the cover in place using a Phillips #00 screwdriver.
    • Remove the 4 screws holding the cover in place using a Phillips #00 screwdriver.
  3. Open the back cover. Lift the cover slowly and carefully; the speaker is screwed on the back cover and is connected to the circuit board.
    • Open the back cover.
    • Lift the cover slowly and carefully; the speaker is screwed on the back cover and is connected to the circuit board.
  4. Disconnect the speaker from the terminal. When reassembling, make sure that you plug the terminal in the same way.  The black wire should be on the side farthest from the battery.
    • Disconnect the speaker from the terminal.
    • When reassembling, make sure that you plug the terminal in the same way. The black wire should be on the side farthest from the battery.
Conclusión
2 personas más completaron esta guía.
Ross Light
Miembro Desde 12/04/10
175 Reputación
6 Guías creadas
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 1
Ultimos 30 días: 5
Todo El Tiempo: 3,314
