Saltar al contenido principal
Removing Lenovo Thinkpad T61p RAM
Qué necesitas
  1. Removing Lenovo Thinkpad T61p RAM, RAM: paso 1, imagen 1 de 2 Removing Lenovo Thinkpad T61p RAM, RAM: paso 1, imagen 2 de 2
    • Place the laptop on a fat surface with the underside facing up
    • Remove the 4 Philips head screws.
    • Turn the computer over and open the display
    • Grasping each side of the palm rest, gently lift it off and rotate toward the front of the laptop
    • The palm rest will be connected to the main board by a ribbon cable
  2. Removing Lenovo Thinkpad T61p RAM: paso 2, imagen 1 de 1
    • Disconnect the touchpad ribbon cable
    • This step is recommended in the service manual however it is possible to remove the RAM without discoinnecting the touchpad cable
  3. Removing Lenovo Thinkpad T61p RAM: paso 3, imagen 1 de 1
    • Locate the RAM modules
    • Gently press the metal tabs outwards to release the top RAM module and remove it from the laptop
    • With the top RAM module removed you can release the lower RAM module in the same manner.
Conclusión
5 personas más completaron esta guía.
Glac1er
Miembro Desde 05/25/13
180 Reputación
1 Guía escrita
Equipo
Glac1er Miembro de Glac1er
Community
1 Miembro
1 Guía escrita
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 2
Ultimos 7 días: 5
Ultimos 30 días: 13
Todo El Tiempo: 9,950
