Saltar al contenido principal
Introducción
Ever want to disassemble and reassemble your Delphi MyFi XM2GO portable XM radio? Follow this guide to learn how to remove the motherboard (PCB logic board) of the Delphi MyFi XM2GO portable XM radio. You will need a Torx T6 screwdriver to complete this guide. Warning: you may have to use your fingernails to pry off certain parts.
Partes
No se especificaron partes.
  1. Locate the large button on the top of the device. Push down on the button and slide the cover away from the button. The battery removal tab may pop up.
    • Locate the large button on the top of the device.
    • Push down on the button and slide the cover away from the button.
    • The battery removal tab may pop up.
  2. Grab the red pull tab and pull down to unlock the latch. Pull the battery out. Pull the battery out.
    • Grab the red pull tab and pull down to unlock the latch.
    • Pull the battery out.
  3. locate the four hex screws on the bottom of the device. Remove the four screws using the T6 Torx screwdriver.
    • locate the four hex screws on the bottom of the device.
    • Remove the four screws using the T6 Torx screwdriver.
  4. Locate the button on the back side of the device. Remove the cover by inserting a flathead screwdriver or thumb nail and lifting up. Remove the cover by inserting a flathead screwdriver or thumb nail and lifting up.
    • Locate the button on the back side of the device.
    • Remove the cover by inserting a flathead screwdriver or thumb nail and lifting up.
  5. Remove the two screws under the button using the T6 Torx screwdriver. Remove the two screws under the button using the T6 Torx screwdriver. Remove the two screws under the button using the T6 Torx screwdriver.
    • Remove the two screws under the button using the T6 Torx screwdriver.
  6. Remove the back cover. Remove the back cover.
    • Remove the back cover.
  7. Locate the power button. Remove the power button by pulling to the left.
    • Locate the power button.
    • Remove the power button by pulling to the left.
  8. Locate the antenna extension connector on the right. Remove the plastic piece.
    • Locate the antenna extension connector on the right.
    • Remove the plastic piece.
  9. Pull up on the PCB Logic Board to remove. The LCD screen and keypad are only connected to the board with ribbon cables. They will hang down as the PCB Logic Board is removed. The LCD screen and keypad are only connected to the board with ribbon cables. They will hang down as the PCB Logic Board is removed.
    • Pull up on the PCB Logic Board to remove.
    • The LCD screen and keypad are only connected to the board with ribbon cables. They will hang down as the PCB Logic Board is removed.
Conclusión
Una persona más ha completado esta guía.
Scott Byer
Miembro Desde 09/03/12
61 Reputación
5 Guías creadas
Equipo
Clemson, Team 1-2, Benson Spring 2012 Miembro de Clemson, Team 1-2, Benson Spring 2012
CLEM-BENSON-S12S1G2
3 Miembros
9 Guías creadas
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 2
Ultimos 30 días: 9
Todo El Tiempo: 2,324
