Herramientas
Partes
No se requieren partes.
Turn over the Delphi MyFi XM2GO Device on its back to start the cover-removal process.
Holding the device, grab the tab with thumb and index figure.
Pull down on the tab to move the battery block a few millimeters towards the bottom of the device to unlock the latch at the top.
After the latch at the top is disengaged, pivot the battery away from the back and the battery will be free.
locate the four hex screws on the bottom of the device.
Use a T6 hex bit from the iFixit precision screwdriver set to remove the four screws.
The logic board must be exposed to begin.
Flip the device over (see second picture).
Locate the white ribbon connector attached to the keyboard.
Catch the sides of the connector with fingernails and pull outward.
After the latch is pulled out, the ribbon cable is free to slide out of the connector housing.
