Saltar al contenido principal
Removing Dell Inspiron 1150 RAM
Qué necesitas
  1. Removing Dell Inspiron 1150 RAM, Removing Dell Inspiron 1150 RAM: paso 1, imagen 1 de 1
    • Turn the laptop so that the bottom is facing up.
    • Locate the panel that has an M on it and two air vents.
  2. Removing Dell Inspiron 1150 RAM: paso 2, imagen 1 de 2 Removing Dell Inspiron 1150 RAM: paso 2, imagen 2 de 2
    • Take the screw driver and carefully unscrew the screw that is located above the M in order to remove the panel.
    • Put this screw in a bag or easily identifiable place.
    • Remove the panel.
  3. Removing Dell Inspiron 1150 RAM: paso 3, imagen 1 de 3 Removing Dell Inspiron 1150 RAM: paso 3, imagen 2 de 3 Removing Dell Inspiron 1150 RAM: paso 3, imagen 3 de 3
    • After removing the panel, you will see two memory modules.
    • Locate the four spring clips that are holding the memory modules in place.
    • Place your thumb on each of the two spring clips for each memory module and push outward until the memory module pops up.
    • Gently raise the memory module and lift it out of its socket.
Conclusión
Christopher
Miembro Desde 04/27/10
8 Reputación
1 Guía escrita
Equipo
Cal Poly, Team 16-2, Maness Spring 2010 Miembro de Cal Poly, Team 16-2, Maness Spring 2010
CPSU-MANESS-S10S16G2
4 Miembros
9 Guías creadas
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 1
Ultimos 7 días: 1
Ultimos 30 días: 5
Todo El Tiempo: 5,823
