Saltar al contenido principal
Removing Dell Inspiron 1150 Optical drive
Qué necesitas
  1. Removing Dell Inspiron 1150 Optical drive, Removing Dell Inspiron 1150 Battery: paso 1, imagen 1 de 3 Removing Dell Inspiron 1150 Optical drive, Removing Dell Inspiron 1150 Battery: paso 1, imagen 2 de 3 Removing Dell Inspiron 1150 Optical drive, Removing Dell Inspiron 1150 Battery: paso 1, imagen 3 de 3
    • Place the laptop upside down on a clean, flat surface.
    • Locate the battery release button with the padlock symbol above it.
    • Slide the battery release button towards the padlock symbol and hold it there. Note that the button is spring loaded and will return if released.
    • The battery is now released from the battery compartment.
    • Gently remove the battery from the side of the laptop.
  2. Removing Dell Inspiron 1150 Optical drive, Removing Dell Inspiron 1150 Palm Rest: paso 2, imagen 1 de 2 Removing Dell Inspiron 1150 Optical drive, Removing Dell Inspiron 1150 Palm Rest: paso 2, imagen 2 de 2
    • Position the computer upside down.
    • Remove the twelve M2.5 x 8-mm screws.
    • Remove the M2.5 x 4-mm screw from the battery bay
  3. Removing Dell Inspiron 1150 Optical drive: paso 3, imagen 1 de 2 Removing Dell Inspiron 1150 Optical drive: paso 3, imagen 2 de 2
    • Position the computer keyboard side up.
    • Remove the two M2.5 x 5-mm screws from the top of the palm rest.
    • Disconnect the mouse pad cable from the main board.
    • Separate the palm rest from the base by lifting its inside edge. Start at the back center.
    • Be careful to avoid damaging the palm rest while separating it from the base.
  4. Removing Dell Inspiron 1150 Optical drive, Removing Dell Inspiron 1150 Optical drive: paso 4, imagen 1 de 3 Removing Dell Inspiron 1150 Optical drive, Removing Dell Inspiron 1150 Optical drive: paso 4, imagen 2 de 3 Removing Dell Inspiron 1150 Optical drive, Removing Dell Inspiron 1150 Optical drive: paso 4, imagen 3 de 3
    • Locate the optical disk drive on the bottom left hand side of the laptop.
    • Remove the single screw holding the optical disk drive in the chassis.
    • Remove the optical disk drive by gently pulling on the outer edge.
Conclusión
Daniel
Miembro Desde 04/25/10
87 Reputación
2 Guías creadas
Equipo
Cal Poly, Team 16-2, Maness Spring 2010 Miembro de Cal Poly, Team 16-2, Maness Spring 2010
CPSU-MANESS-S10S16G2
4 Miembros
9 Guías creadas
Un comentario
This guide is incorrect, please see http://support.dell.com/support/edocs/sy... for a version that will actually take the promised two minutes.
Nick - Contestar
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 0
Ultimos 30 días: 1
Todo El Tiempo: 5,869
