Saltar al contenido principal
Removing Dell Inspiron 1150 Battery
  1. Removing Dell Inspiron 1150 Battery, Removing Dell Inspiron 1150 Battery: paso 1, imagen 1 de 3 Removing Dell Inspiron 1150 Battery, Removing Dell Inspiron 1150 Battery: paso 1, imagen 2 de 3 Removing Dell Inspiron 1150 Battery, Removing Dell Inspiron 1150 Battery: paso 1, imagen 3 de 3
    • Place the laptop upside down on a clean, flat surface.
    • Locate the battery release button with the padlock symbol above it.
    • Slide the battery release button towards the padlock symbol and hold it there. Note that the button is spring loaded and will return if released.
    • The battery is now released from the battery compartment.
    • Gently remove the battery from the side of the laptop.
Linea de Meta
6 personas más completaron esta guía.
Teja
Miembro Desde 04/27/10
98 Reputación
3 Guías creadas
Equipo
Cal Poly, Team 16-2, Maness Spring 2010 Miembro de Cal Poly, Team 16-2, Maness Spring 2010
CPSU-MANESS-S10S16G2
4 Miembros
9 Guías creadas
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 0
Ultimos 30 días: 5
Todo El Tiempo: 10,854
