Saltar al contenido principal
Removing DVD Drive from Acer Aspire 5100
Qué necesitas
  1. Removing DVD Drive from Acer Aspire 5100, Removing DVD Drive from Acer Aspire 5100: paso 1, imagen 1 de 2 Removing DVD Drive from Acer Aspire 5100, Removing DVD Drive from Acer Aspire 5100: paso 1, imagen 2 de 2
    • Locate tab with battery symbol on back of laptop. Slide to left to eject battery.
  2. Removing DVD Drive from Acer Aspire 5100: paso 2, imagen 1 de 1
    • Locate cover on back of laptop, diagonal to battery compartment. Remove four screws securing cover.
  3. Removing DVD Drive from Acer Aspire 5100: paso 3, imagen 1 de 2 Removing DVD Drive from Acer Aspire 5100: paso 3, imagen 2 de 2
    • After removing screws, carefully detach cover. You will see the cooling fan in the corner.
  4. Removing DVD Drive from Acer Aspire 5100: paso 4, imagen 1 de 2 Removing DVD Drive from Acer Aspire 5100: paso 4, imagen 2 de 2
    • Opposite the cooling fan is the component that contains the RAM card. Remove the screws holding the component in place. Carefully detach the component to expose the RAM card.
  5. Removing DVD Drive from Acer Aspire 5100: paso 5, imagen 1 de 1
    • Locate the DVD drive and remove screw securing drive. Carefully push drive out from laptop.
Conclusión
To reassemble, follow above steps in reverse.
2 personas más completaron esta guía.
luis
Miembro Desde 04/21/10
167 Reputación
1 Guía escrita
Equipo
Cal Poly, Team 18-66, Johann Spring 2010 Miembro de Cal Poly, Team 18-66, Johann Spring 2010
CPSU-JOHANN-S10S18G66
5 Miembros
1 Guía escrita
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 1
Ultimos 7 días: 16
Ultimos 30 días: 20
Todo El Tiempo: 2,788
