Saltar al contenido principal
Removing Creative Zen Vision W Back Cover
Qué necesitas
  1. Removing Creative Zen Vision W Back Cover, Battery Removal: paso 1, imagen 1 de 3 Removing Creative Zen Vision W Back Cover, Battery Removal: paso 1, imagen 2 de 3 Removing Creative Zen Vision W Back Cover, Battery Removal: paso 1, imagen 3 de 3
    • Push the black button and slide the battery casing to the left simultaneously, until the battery is completely separated from the device.
  2. Removing Creative Zen Vision W Back Cover, Back Cover: paso 2, imagen 1 de 1
    • Remove the 2 screws (3.5 mm) on the Compact Flash insert, located on the left hand side, with a Phillips #000 screwdriver.
  3. Removing Creative Zen Vision W Back Cover: paso 3, imagen 1 de 2 Removing Creative Zen Vision W Back Cover: paso 3, imagen 2 de 2
    • Remove the 5 screws (5.5 mm), circled in red, using a Phillips #0. Use a flashlight if necessary.
    • Peel off the sticker that says "Creative warranty void if broken" and remove the screw (5.5 mm) underneath with a Phillips #0.
    • Be careful, some of the screws are difficult to see and can be easily stripped.
  4. Removing Creative Zen Vision W Back Cover: paso 4, imagen 1 de 3 Removing Creative Zen Vision W Back Cover: paso 4, imagen 2 de 3 Removing Creative Zen Vision W Back Cover: paso 4, imagen 3 de 3
    • Carefully pull the back cover off of the rest of the device.
    • The volume control buttons and power slider may fall off when removing the cover, do not lose these small pieces.
    • The USB input cover on the bottom of the device may also fall off.
Conclusión
Gabriele Pregadio
Miembro Desde 04/17/13
1 Reputación
2 Guías creadas
Equipo
Cal Poly, Team 17-2, Regan Spring 2013 Miembro de Cal Poly, Team 17-2, Regan Spring 2013
CPSU-REGAN-S13S17G2
4 Miembros
8 Guías creadas
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 1
Ultimos 30 días: 2
Todo El Tiempo: 717
