Saltar al contenido principal
Únete a la Comunidad de Reparación - Crear Cuenta
Removing Bottom of iMac G4 15" 700 MHz EMC 1873
Qué necesitas
  1. Removing Bottom of iMac G4 15" 700 MHz EMC 1873, Outer Base Plate: paso 1, imagen 1 de 2 Removing Bottom of iMac G4 15" 700 MHz EMC 1873, Outer Base Plate: paso 1, imagen 2 de 2
    • Place the computer monitor face down on a safe, harmless surface.
    • Using a Phillips #00 screw driver, remove the four 6.86 mm screws from the metal plate.
  2. Removing Bottom of iMac G4 15" 700 MHz EMC 1873: paso 2, imagen 1 de 1
    • Remove the metal plate from bottom of the iMac G4.
    • The four screws do not completely separate from the metal plate.
  3. Removing Bottom of iMac G4 15" 700 MHz EMC 1873, RAM DIMM: paso 3, imagen 1 de 2 Removing Bottom of iMac G4 15" 700 MHz EMC 1873, RAM DIMM: paso 3, imagen 2 de 2
    • Release the tabs on each side of the module by simultaneously pushing each tab away from the RAM.
    • These tabs lock the module in place and releasing them will cause the module to "pop" up.
    • Remove the RAM module from the iMac.
  4. Removing Bottom of iMac G4 15" 700 MHz EMC 1873, AirPort Card: paso 4, imagen 1 de 1
    • Use a spudger to lift and remove the AirPort's antenna connector.
    • This step is only applicable to iMacs that came with an AirPort card installed.
  5. Removing Bottom of iMac G4 15" 700 MHz EMC 1873, Removing the Lower Case: paso 5, imagen 1 de 1
    • Remove the four 28.07mm Torx #15 screws from the lower case.
  6. Removing Bottom of iMac G4 15" 700 MHz EMC 1873: paso 6, imagen 1 de 2 Removing Bottom of iMac G4 15" 700 MHz EMC 1873: paso 6, imagen 2 de 2
    • Open the base by carefully pulling straight off, do not rotate the cover.
    • Open slowly to ensure that no cables are damaged or disconnected.
  7. Removing Bottom of iMac G4 15" 700 MHz EMC 1873: paso 7, imagen 1 de 1
    • Squeeze the small black tab and wiggle gently to remove the colored power cable.
    • Do not pull directly on the colored wires.
    • Do not remove black grounding wire.
  8. Removing Bottom of iMac G4 15" 700 MHz EMC 1873: paso 8, imagen 1 de 1
    • Grab both sides of the blue connector and firmly pull to remove it from the mother board.
    • Do not pull directly on the ribbon cable.
Conclusión
10 personas más completaron esta guía.
Elliot Freerks
Miembro Desde 10/04/11
932 Reputación
3 Guías creadas
Equipo
Cal Poly, Team 5-32, Amido Fall 2011 Miembro de Cal Poly, Team 5-32, Amido Fall 2011
CPSU-AMIDO-F11S5G32
Miembros de 4
16 Guías creadas
1Guía Comentario
Do I need to apply thermal paste? Or it is not necessary?
willynanita - Contestar Compartir
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 2
Ultimos 7 días: 24
Ultimos 30 días: 77
Todo El Tiempo: 7,332
