Saltar al contenido principal
Removing Back Cover
Qué necesitas
  1. Removing Back Cover, Removing Back Cover: paso 1, imagen 1 de 3 Removing Back Cover, Removing Back Cover: paso 1, imagen 2 de 3 Removing Back Cover, Removing Back Cover: paso 1, imagen 3 de 3
    • Remove the six external screws from the camera using a Phillips #0 screwdriver.
    • After the screws has been removed, the bottom of the back half of the external case should be loosened from the camera.
    • Be careful, make sure you don't lose the screws.
  2. Removing Back Cover: paso 2, imagen 1 de 2 Removing Back Cover: paso 2, imagen 2 de 2
    • Open the battery cover that's located on the bottom right side of the camera and carefully remove the battery.
  3. Removing Back Cover: paso 3, imagen 1 de 3 Removing Back Cover: paso 3, imagen 2 de 3 Removing Back Cover: paso 3, imagen 3 de 3
    • Slide your fingernail or a plastic spudger in the groove from the bottom to the top right side of the camera.
  4. Removing Back Cover: paso 4, imagen 1 de 1
    • Carefully squeeze the top right corner of the camera and pry off the external cover.
    • If you hear a "cracking" sound. This is normal.
    • Continue to pull the external cover and it will come off cleanly.
    • Be cautious of the flash capacitor. It carries an electrical charge, that may give you an unpleasant shock.
  5. Removing Back Cover: paso 5, imagen 1 de 1
    • Carefully pull off the back cover, parts behind the back of the case might fall out.
Linea de Meta
3 personas más completaron esta guía.
Hasit
Miembro Desde 04/15/10
195 Reputación
2 Guías creadas
Equipo
Cal Poly, Team 6-17, Maness Spring 2010 Miembro de Cal Poly, Team 6-17, Maness Spring 2010
CPSU-MANESS-S10S6G17
4 Miembros
10 Guías creadas
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 3
Ultimos 30 días: 42
Todo El Tiempo: 4,028
