Saltar al contenido principal
Únete a la Comunidad de Reparación - Crear Cuenta
Removing Aftermarket Vehicle Window Tinting
Qué necesitas
    1. Removing Aftermarket Vehicle Window Tinting, Before Photos: paso 1, imagen 1 de 3 Removing Aftermarket Vehicle Window Tinting, Before Photos: paso 1, imagen 2 de 3 Removing Aftermarket Vehicle Window Tinting, Before Photos: paso 1, imagen 3 de 3
      • This is what your window will look like before.
      • And the third photo shows what it will look like after!
      Pregunta a FixBot
      Agregar Comentario
    2. Removing Aftermarket Vehicle Window Tinting: paso 2, imagen 1 de 2 Removing Aftermarket Vehicle Window Tinting: paso 2, imagen 2 de 2
      • Roll down the window about 1/4 of the way so you can start to remove the tint from the top.
      Pregunta a FixBot
      Agregar Comentario
    3. Removing Aftermarket Vehicle Window Tinting: paso 3, imagen 1 de 3 Removing Aftermarket Vehicle Window Tinting: paso 3, imagen 2 de 3 Removing Aftermarket Vehicle Window Tinting: paso 3, imagen 3 de 3
      • Heat the area with a heat gun at the window's edge.
      • Start by using the low setting on the heat gun to gradually heat the surface. After the area has warmed up, you can switch to high heat to make it easier to remove the film.
      • Use the razor blade to peel a small area of the tint film up.
      Pregunta a FixBot
      Agregar Comentario
    4. Removing Aftermarket Vehicle Window Tinting: paso 4, imagen 1 de 2 Removing Aftermarket Vehicle Window Tinting: paso 4, imagen 2 de 2
      • Once you've peeled enough with the razor blade to use your fingers, heat the area, then peel with your fingers.
      • Don't pull with your fingers and heat the area with the gun simultaneously. You'll burn yourself.
      • Heat the film angling the heat gun up. This will ensure that the film will not rip easily.
      Pregunta a FixBot
      Agregar Comentario
    5. Removing Aftermarket Vehicle Window Tinting: paso 5, imagen 1 de 1
      • When you've pulled enough film off so that you don't burn your fingers while simultaneously pulling, use a back-and-forth motion with the heat gun along the area where the film is still on the window while pulling on the film. (See next step)
      Pregunta a FixBot
      Agregar Comentario
      • How to heat the area with the heat gun.
      Pregunta a FixBot
      Agregar Comentario
    6. Removing Aftermarket Vehicle Window Tinting: paso 7, imagen 1 de 2 Removing Aftermarket Vehicle Window Tinting: paso 7, imagen 2 de 2
      • Once you have removed the film from the top of the window, you can roll up the window.
      • Continue doing a back-and-forth motion and pulling on the film until all of the film comes off.
      • If the film rips, no worries. Just continue. You can heat up those sections and remove them later.
      Pregunta a FixBot
      Agregar Comentario
    7. Removing Aftermarket Vehicle Window Tinting: paso 8, imagen 1 de 2 Removing Aftermarket Vehicle Window Tinting: paso 8, imagen 2 de 2
      • Once you have removed all of the film, spray the window with glass cleaner and clean the window with either a rag or paper towel.
      Pregunta a FixBot
      Agregar Comentario
    8. Removing Aftermarket Vehicle Window Tinting: paso 9, imagen 1 de 2 Removing Aftermarket Vehicle Window Tinting: paso 9, imagen 2 de 2
      • For areas where some residue is still on the window, spray the area with glass cleaner and use the razor blade to scrape the area to remove the residue.
      • For really tough residue, use Goo Gone in lieu of glass cleaner.
      Pregunta a FixBot
      Agregar Comentario
    9. Removing Aftermarket Vehicle Window Tinting: paso 10, imagen 1 de 2 Removing Aftermarket Vehicle Window Tinting: paso 10, imagen 2 de 2
      • First photo: Before
      • Second photo: After
      Pregunta a FixBot
      Agregar Comentario
    10. Removing Aftermarket Vehicle Window Tinting, Before and After: paso 11, imagen 1 de 2 Removing Aftermarket Vehicle Window Tinting, Before and After: paso 11, imagen 2 de 2
      Pregunta a FixBot
      Agregar Comentario
Conclusión
You are finished! Repeat the steps in this guide for every window you wish to remove the tinting.
Una persona más ha completado esta guía.
S.I. Dalton
Miembro Desde 09/05/24
1,728 Reputación
4 Guías creadas
Equipo
Apple fan boys Miembro de Apple fan boys
Community
Miembros de 57
342 Guías creadas
0Guía Comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 3
Ultimos 7 días: 17
Ultimos 30 días: 64
Todo El Tiempo: 829
