Saltar al contenido principal
Removing 2005-2007 Ford Focus Front Wheel
Sólo Prerrequisito
Esta guía solo debería usarse como prerrequisito para otras guías. Por tanto, estará incompleta.
Qué necesitas
  1. Removing 2005-2007 Ford Focus Front Wheel, Front Wheel: paso 1, imagen 1 de 1
    • Put the car in park (automatic) or neutral (manual).
    • Apply the parking brake.
    • Place chocks behind the rear wheels.
  2. Removing 2005-2007 Ford Focus Front Wheel: paso 2, imagen 1 de 1
    • Use a 19 mm lug wrench to loosen each lug nut a half turn.
  3. Removing 2005-2007 Ford Focus Front Wheel: paso 3, imagen 1 de 2 Removing 2005-2007 Ford Focus Front Wheel: paso 3, imagen 2 de 2
    • Use a hydraulic jack on the car's frame to jack the car.
    • A small notch shows where to place the jack.
    • It is only necessary to jack the car until the wheel no longer touches the ground.
  4. Removing 2005-2007 Ford Focus Front Wheel: paso 4, imagen 1 de 1
    • Place a jack stand on the frame and remove the jack.
    • Never work on or underneath a car that is only supported by a jack. The car may fall, causing serious injury, or even death.
  5. Removing 2005-2007 Ford Focus Front Wheel: paso 5, imagen 1 de 2 Removing 2005-2007 Ford Focus Front Wheel: paso 5, imagen 2 de 2
    • Use a lug wrench to completely remove the four lug nuts.
    • Remove the wheel.
Linea de Meta
David Hodson
Miembro Desde 04/13/10
150,882 Reputación
127 Guías creadas
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 0
Ultimos 30 días: 11
Todo El Tiempo: 2,077
