Saltar al contenido principal
Removing factory feet from a Mac Laptop (Non-Retina)
Qué necesitas
  1. Removing factory feet from a Mac Laptop (Non-Retina), Remove the bottom cover: paso 1, imagen 1 de 2 Removing factory feet from a Mac Laptop (Non-Retina), Remove the bottom cover: paso 1, imagen 2 de 2
    • I am using a 2011 13" MacBook Pro. Most machines are similar, but variations may exist.
    • If possible, disconnect the battery to protect your components once the bottom is removed.
    • Remove the bottom cover of your MacBook with the guide for your specific system.
  2. Removing factory feet from a Mac Laptop (Non-Retina), Removing failed feet: paso 2, imagen 1 de 3 Removing factory feet from a Mac Laptop (Non-Retina), Removing failed feet: paso 2, imagen 2 de 3 Removing factory feet from a Mac Laptop (Non-Retina), Removing failed feet: paso 2, imagen 3 de 3
    • Before removing the good feet, remove the failed feet first. These may come off without disassembly if they have fully failed.
    • After removing the damaged feet, remove the intact feet. Follow the disassembly guide for your specific Mac.
  3. Removing factory feet from a Mac Laptop (Non-Retina), (Full set replacement only) Removing intact feet: paso 3, imagen 1 de 3 Removing factory feet from a Mac Laptop (Non-Retina), (Full set replacement only) Removing intact feet: paso 3, imagen 2 de 3 Removing factory feet from a Mac Laptop (Non-Retina), (Full set replacement only) Removing intact feet: paso 3, imagen 3 de 3
    Herramienta utilizada en este paso:
    iFixit Opening Picks (Set of 6)
    Comprar
    • To remove the intact feet, score the internal plug. Once scored, remove the plug with a guitar pick.
    • After removing the inner plug, push the foot out with a spudger or screwdriver.
  4. Removing factory feet from a Mac Laptop (Non-Retina), Install the new feet: paso 4, imagen 1 de 2 Removing factory feet from a Mac Laptop (Non-Retina), Install the new feet: paso 4, imagen 2 de 2
    Adhesive Cleanup Kit (Set of 12)
    Comprar
    • If the adhesive ring remains, remove it first. Clean the chassis with denatured alcohol or adhesive cleaner.
    • After removing the old feet, install the new set onto the bottom cover.
    • Re-install the cover on the computer.
Linea de Meta
4 personas más completaron esta guía.
Nick
Miembro Desde 11/10/09
88,752 Reputación
49 Guías creadas
Equipo
Master Techs Miembro de Master Techs
Community
322 Miembros
2,521 Guías creadas
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 3
Ultimos 7 días: 19
Ultimos 30 días: 61
Todo El Tiempo: 4,349
