Saltar al contenido principal
Remove the Screen
Qué necesitas
  1. Remove the Screen, Remove Screws: paso 1, imagen 1 de 3 Remove the Screen, Remove Screws: paso 1, imagen 2 de 3 Remove the Screen, Remove Screws: paso 1, imagen 3 de 3
    • Remove the screws from the bottom, right, and left side of camera.
  2. Remove the Screen, Remove back: paso 2, imagen 1 de 1
    • Remove the back of the camera, this may require force.
  3. Remove the Screen, Remove Metal Bracket: paso 3, imagen 1 de 1
    • Unscrew the right metal bracket of the viewing lens
  4. Remove the Screen, Remove front of camera: paso 4, imagen 1 de 1
    • Unscrew the top right corner screw
  5. Remove the Screen: paso 5, imagen 1 de 1
    • Unscrew the bottom right corner screw.
  6. Remove the Screen: paso 6, imagen 1 de 2 Remove the Screen: paso 6, imagen 2 de 2
    • Pull the grey circular facet that sits on the bottom outside of the camera off - may have to use force.
  7. Remove the Screen: paso 7, imagen 1 de 2 Remove the Screen: paso 7, imagen 2 de 2
    • Pull the front of the camera off of the mother board.
  8. Remove the Screen, Remove the Screen: paso 8, imagen 1 de 1
    • Unhinge the outer case of the screen from the back of the camera. The screen should still be hanging by wires.
  9. Remove the Screen: paso 9, imagen 1 de 1
    • Remove outer case/rim of screen from the back of the camera. The screen should still be hanging by the red wire and white wire.
  10. Remove the Screen: paso 10, imagen 1 de 1
    • Pull out the red wire and white wire attaching the screen to the motherboard.
  11. Remove the Screen: paso 11, imagen 1 de 1
    • Flip up black lever holding data cable to motherboard, and remove data cable from motherboard.
Conclusión
Una persona más ha completado esta guía.
Melissa
Miembro Desde 02/12/13
240 Reputación
2 Guías creadas
Equipo
Ohio State, Team 1-2, Buehl Spring 2013 Miembro de Ohio State, Team 1-2, Buehl Spring 2013
OSU-BUEHL-S13S1G2
2 Miembros
7 Guías creadas
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 0
Ultimos 30 días: 10
Todo El Tiempo: 396
