Saltar al contenido principal
Remove PowerMac G4 M5183 Main Fan
Qué necesitas
  1. Remove PowerMac G4 M5183 Main Fan, Opening PowerMac G4 M5183 Case: paso 1, imagen 1 de 2 Remove PowerMac G4 M5183 Main Fan, Opening PowerMac G4 M5183 Case: paso 1, imagen 2 de 2
    • Pull on outer latch.
    • Lower door until it is level with your work surface.
    • Before working on the computer make sure it is not plugged into a power supply, then touch a metal object. This discharges static electricity, which could damage the computer.
  2. Remove PowerMac G4 M5183 Main Fan, Main Fan: paso 2, imagen 1 de 2 Remove PowerMac G4 M5183 Main Fan, Main Fan: paso 2, imagen 2 de 2
    • Remove the screw from each of the two niches on lower part of fan using the Phillips #1 screwdriver.
    • The fan housing will still be connected to the computer by a power cable which will be removed in the next step.
  3. Remove PowerMac G4 M5183 Main Fan: paso 3, imagen 1 de 1
    • Remove the power cable from the fan and detach bracing.
Linea de Meta
2 personas más completaron esta guía.
Justin Petrilli
Miembro Desde 01/21/10
3,114 Reputación
11 Guías creadas
Equipo
Cal Poly, Team 13-24, Maness Winter 2010 Miembro de Cal Poly, Team 13-24, Maness Winter 2010
CPSU-MANESS-W10S13G24
4 Miembros
25 Guías creadas
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 2
Ultimos 7 días: 7
Ultimos 30 días: 21
Todo El Tiempo: 5,493
