Saltar al contenido principal
Remove IBM WorkPad c3 Battery
Qué necesitas
  1. Remove IBM WorkPad c3 Battery, Back Case: paso 1, imagen 1 de 2 Remove IBM WorkPad c3 Battery, Back Case: paso 1, imagen 2 de 2
    • Turn the device over so that the screen is facing down.
    • In the next step the device will be heated, so the screen must be turned over to prevent heat damage to the LCD/Digitizer.
  2. Remove IBM WorkPad c3 Battery: paso 2, imagen 1 de 1
    • Using a hair dryer, slowly heat the edges of the WorkPad.
    • Spend at least one minute heating each side of the device. This will melt the glue holding the case together, and allow it to be removed.
    • Be sure not to touch the device directly after heating as it will be extremely hot. Use a towel or oven mitt to grab it.
  3. Remove IBM WorkPad c3 Battery: paso 3, imagen 1 de 2 Remove IBM WorkPad c3 Battery: paso 3, imagen 2 de 2
    • Use a plastic opening tool to pry the back case from the WorkPad.
    • If the rear cover is not coming off very easily, you probably need to reheat the case in order to sufficiently melt the glue.
  4. Remove IBM WorkPad c3 Battery, Battery: paso 4, imagen 1 de 1
    • Remove the yellow tape that is covering the battery connector
  5. Remove IBM WorkPad c3 Battery: paso 5, imagen 1 de 1
    Herramienta utilizada en este paso:
    Comprar
    • Using the tweezers, carefully disconnect the battery cable from the port
  6. Remove IBM WorkPad c3 Battery: paso 6, imagen 1 de 2 Remove IBM WorkPad c3 Battery: paso 6, imagen 2 de 2
    • Using the plastic opening tools, lift the battery out of the case
    • The battery is secured with adhesive and it will take some effort to remove
Conclusión
Una persona más ha completado esta guía.
Equipo
Cal Poly, Team 21-35, Regan Fall 2010 Miembro de Cal Poly, Team 21-35, Regan Fall 2010
CPSU-REGAN-F10S21G35
3 Miembros
5 Guías creadas
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 1
Ultimos 30 días: 33
Todo El Tiempo: 4,241
