Saltar al contenido principal
Introducción
Use this guide to assist with general disassembly or troubleshooting of your braille display.
Partes
No se especificaron partes.
  1. Removal of super-vario 40 braille display, Removal of super-vario 40 braille display: paso 1, imagen 1 de 2 Removal of super-vario 40 braille display, Removal of super-vario 40 braille display: paso 1, imagen 2 de 2
    • Remove the four bottom screws with a Phillips #00 screwdriver.
  2. Removal of super-vario 40 braille display: paso 2, imagen 1 de 3 Removal of super-vario 40 braille display: paso 2, imagen 2 de 3 Removal of super-vario 40 braille display: paso 2, imagen 3 de 3
    • Remove the plastic cover, paper and chipset.
  3. Removal of super-vario 40 braille display: paso 3, imagen 1 de 3 Removal of super-vario 40 braille display: paso 3, imagen 2 de 3 Removal of super-vario 40 braille display: paso 3, imagen 3 de 3
    • Remove the two screws with a Phillips #00 screwdriver on the logic board.
    • take out the main circuit like show in the picture
  4. Removal of super-vario 40 braille display: paso 4, imagen 1 de 3 Removal of super-vario 40 braille display: paso 4, imagen 2 de 3 Removal of super-vario 40 braille display: paso 4, imagen 3 de 3
    • Remove the four screws with a Phillips #00 screwdriver.
  5. Removal of super-vario 40 braille display: paso 5, imagen 1 de 3 Removal of super-vario 40 braille display: paso 5, imagen 2 de 3 Removal of super-vario 40 braille display: paso 5, imagen 3 de 3
    • Remove the connector delicately.
  6. Removal of super-vario 40 braille display: paso 6, imagen 1 de 2 Removal of super-vario 40 braille display: paso 6, imagen 2 de 2
    • when you put it back together make sure mechanical cells are connected correctly
Conclusión
Sisyphe
Miembro Desde 29/07/13
332 Reputación
2 Guías creadas
2 comentarios
great guide!  how can I repair a VarioUltra 20?  are the procedures similar?  the device has a problem at point 4 of the sixth cell, the point moves unsteadily, should I replace this whole cell or is it possible to just repair point 4, which is defective?
marcusvinicioslira - Contestar
which professional will likely be able to repair a braille display?  should I look for an electrical engineer or other professional?  I'm blind, I don't repair electronics, but I have a defective braille display that needs to be repaired.  I live in a country where there are no companies capable of repairing this product.  I do not know what to think.  sending the product to a specialized company in another country is very expensive for me.
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 1
Ultimos 30 días: 6
Todo El Tiempo: 808
