Saltar al contenido principal
Remington S5500 Ceramic Plate Removal
Qué necesitas
  1. Remington S5500 Ceramic Plate Removal, Ceramic Plate Removal: paso 1, imagen 1 de 3 Remington S5500 Ceramic Plate Removal, Ceramic Plate Removal: paso 1, imagen 2 de 3 Remington S5500 Ceramic Plate Removal, Ceramic Plate Removal: paso 1, imagen 3 de 3
    • Using a Phillips #1 screwdriver, remove the 3 screws holding the black plastic cover in place.
    • Pull upwards and remove the black plastic cover.
    • Remove the ceramic plate by pulling the plate parallel to the straightener, while pulling upwards.
  2. Remington S5500 Ceramic Plate Removal: paso 2, imagen 1 de 3 Remington S5500 Ceramic Plate Removal: paso 2, imagen 2 de 3 Remington S5500 Ceramic Plate Removal: paso 2, imagen 3 de 3
    • Using a Phillips #1 screwdriver, remove the 3 screws holding the black plastic cover in place. The screws are located in the same places as the other side.
    • Remove the two screws off of the chip using a Phillips #1 screwdriver.
    • Pull off the chip with the same method as the black plastic cover.
  3. Remington S5500 Ceramic Plate Removal: paso 3, imagen 1 de 2 Remington S5500 Ceramic Plate Removal: paso 3, imagen 2 de 2
Conclusión
Benjamin Yohe
Miembro Desde 07/11/18
303 Reputación
2 Guías creadas
Equipo
IUPUI, Team S3-G3, Wilson Summer 2018 Miembro de IUPUI, Team S3-G3, Wilson Summer 2018
IUPUI-WILSON-SU18S3G3
5 Miembros
2 Guías creadas
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 1
Ultimos 7 días: 11
Ultimos 30 días: 48
Todo El Tiempo: 2,401
