Saltar al contenido principal
Regaining deleted files from empty trash in Mac OS X
Guía Archivada
Esta guía se mantiene únicamente para fines históricos. Utiliza la última versión de la guía para llevar a cabo tu reparación.
  1. Regaining deleted files from empty trash in Mac OS X, Regaining deleted files from empty trash in Mac OS X: paso 1, imagen 1 de 1
    • Download a free demo version of Mac file recovery software. Install it on your Mac and launch the user interface to begin.
  2. Regaining deleted files from empty trash in Mac OS X: paso 2, imagen 1 de 1
    • In the software interface, find the 'Deleted File Recovery' feature from the menu and click it to proceed.
  3. Regaining deleted files from empty trash in Mac OS X: paso 3, imagen 1 de 1
    • After doing that, you need to select the hard drive or the volumes from the left side display. Here you can either choose the main hard drive or the selected volume. In the past if you have deleted many files then you can select the main hard drive. Once you select a volume or the hard drive upon which the action has to be taken, hit the 'Continue'
  4. Regaining deleted files from empty trash in Mac OS X: paso 4, imagen 1 de 1
    • Now the scanning of the selected volume/hard drive begins. The software scans the entire hard drive scanning for the deleted files. It may take more or less of the time depending upon the size of the hard drive. After the scan is over, user can see a list of files that can be recovered in a tree structure.
  5. Regaining deleted files from empty trash in Mac OS X: paso 5, imagen 1 de 1
Conclusión
3 personas más completaron esta guía.
Vishal Chaudhary
Miembro Desde 04/18/12
3,203 Reputación
3 Guías creadas
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 0
Ultimos 30 días: 0
Todo El Tiempo: 2,290
