Introducción
If you forgot your password, or you want to delete all data, or you have problem with power on the tablet...
Please SUBSCRIBE to my channel ツ
Resumen del Video
  1. - Make Surface turned off and plugged in. - Insert the USB recovery drive into the USB port. - Press and hold the Volume Down button, press the Power button in a short time.
    • - Make Surface turned off and plugged in.
    • - Insert the USB recovery drive into the USB port.
    • - Press and hold the Volume Down button, press the Power button in a short time.
    • - When the Surface logo appears, release the Volume button.
    • - Select the language and keyboard layout.
  2. ¡Envío gratuito para todos los pedidos de más de USD100.00 o que contengan un Pro Tech Toolkit!
    Visita Nuestra Tienda
    ¿Alguna vez arreglaste algo? Eso es genial.
    Comparte tu historia de reparación con #SoyUnGenio
    Todos somos Genios
  3. Now you are in the Advanced Startup Options menu. You can choose from: - Refresh your PC - Reset your PC
    • Now you are in the Advanced Startup Options menu. You can choose from:
    • - Refresh your PC
    • - Reset your PC
    • ...or from Advanced options menu:
    • - Start-up repair
    • - Command prompt
    • Please SUBSCRIBE to my channel ツ
Conclusión
6 personas más completaron esta guía.
ZFix
Miembro Desde 09/12/13
162,554 Reputación
304 Guías creadas
Equipo
Master Techs Miembro de Master Techs
Community
280 Miembros
784 Guías creadas
Hello.my surface rt is not working properly.The windows is on and off.What should i do?
Muzahar - Contestar
Hello.My surface rt is not working properly.
The windows display is on and off. What should i do to prenvent it?
Muzahar - Contestar
Hello!
RT is not working properly ! I have Surface RT arm and no eny possibility to come in to uefi even I press upp vol. and press on. The tablet will no start and will not to be able on for around 3 \4 minutes. The USB with the windows is it in but when I tray to start with vol down and press on not working like the video shwoing. :(
pigi01se - Contestar
Ver Estadísticas:
Ultimas 24 Horas: 1
Últimos 7 Días: 8
Últimos 30 Días: 42
Todo El Tiempo: 4,206
