Saltar al contenido principal
Reformat SD Card
  1. Reformat SD Card, Reformat SD Card: paso 1, imagen 1 de 2 Reformat SD Card, Reformat SD Card: paso 1, imagen 2 de 2
    • Turn the camera on by sliding the switch from the "Off" position to the "On" position. The switch is located above the touchscreen and to the left.
    • The screen will say "Sensor cleaning" once the switch is moved to "On".
  2. Reformat SD Card: paso 2, imagen 1 de 1
    • Push the black button that says "Menu", located below the "ON/OFF" switch.
  3. Reformat SD Card: paso 3, imagen 1 de 1
    • Using the thumb pad, scroll to the 9th menu from the left.
  4. Reformat SD Card: paso 4, imagen 1 de 1
    • Scroll down the list using the thumb pad and select, "Format card" by pressing the center of the thumb pad labeled, "SET".
  5. Reformat SD Card: paso 5, imagen 1 de 2 Reformat SD Card: paso 5, imagen 2 de 2
    • Once you select "OK", all pictures will be erased from the SD Card.
    • Press the right side of the thumb pad to move over the "Ok" button.
    • Once "OK" is highlighted, press the middle of thumb pad to initiate the formatting of the card.
  6. Reformat SD Card: paso 6, imagen 1 de 1
    • Wait.
  7. Reformat SD Card: paso 7, imagen 1 de 1
    • SD Card is now formatted.
Conclusión
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 1
Ultimos 7 días: 7
Ultimos 30 días: 21
Todo El Tiempo: 781
