Introducción
Utiliza esta guía para quitar la cubierta posterior del Sony Xperia Z3 Compact.
Qué necesitas
Calienta los bordes de la tapa para ablandar el pegamento.
Para volver a ensamblar el dispositivo, sigue estas instrucciones en orden inverso.
38 personas más completaron esta guía.
Un agradecimiento especial a estos traductores:
100%
¡ Francisco Javier Saiz Esteban nos está ayudando a reparar el mundo! ¿Quieres contribuir?
Empezar a traducir ›
8Guía Comentarios
I think this guide shows how to open a phone that's already been opened. I have seen another that showed all the glue between the battery and the back cover that can take a lot of effort to remove, plus once done then (if it was before) it will not longer be waterproof.
I replaced battery cover and I heat up new one. It looks like it become waterproof again.
It will no longer be waterproof, unless you are using the exact same quality and amount of adhesive as the original one, and you press the back glass to the phone as hard as it was before.
If not, then it is hardly waterproof.
I used a domestic hair dryer for about 2 minutes to heat the back of the phone which softened the glue enough for the rear panel to be removed. A layer of glue remained around the frame. The replacement part also had a gummed edge and stuck quite firmly without needing any pressure.
I reheated the rear to soften the new glue and then held the phone in two small clamps gently but firmly until the phone had cooled (overnight as it was convenient).
The phone is waterproof.
Do not forget to clean the phone (remove the rest of the glue sticking on the phone). It will fit better with no old glue.
