Introducción
Utilice esta guía para reemplazar la placa de conectores del OP-1, incluido el micrófono, los conectores de entrada/salida de línea y el puerto USB.
Qué necesitas
Abra el panel trasero usando una herramienta de corte en el lateral. Tenga cuidado de no dañar el revestimiento OP-1.
Levante el panel trasero y retírelo. Queda expuesta la placa de conectores.
Desconecte el conector flexible levantándolo con un spudger.
Retire los tres tornillos Phillips. No pierda la arandela del tornillo inferior.
Retire la placa del conector.
Para volver a ensamblar el dispositivo, siga estas instrucciones en orden inverso.
48 personas más completaron esta guía.
Un agradecimiento especial a estos traductores:
100%
¡ Angel nos está ayudando a reparar el mundo! ¿Quieres contribuir?
Empezar a traducir ›
44Guía Comentarios
Veeery useful , thank you !
Even with the Jimmy I can't seem to get the back panel off... a video would be helpful :)
Got the back panel off finally but my connector board won't come out.
Ok... finally got the connector board out. It took a bit of gentle prying using a very small thin screw driver bit on each side of the connector board. Once I had the right side popped up a bit I was able to push on the input output jacks from the outside to get clearance. Removing the connector board and putting it back in resolved the power switch issues I was experiencing. No new connector board needed! :)
Im so glad I was reading these comments. I had an OP1 with failing power as well, every bit more tougher touch would turn it off and on, or sometimes would have problems starting up.
I took it apart to see if something was bothering, and taking off the white power switch actually solved it haha.
Good I didnt order it yet!
