Introducción
Para desmontar una tableta, a menudo es necesario hacer palanca con cuidado en el marco. ¡Ten cuidado durante estos primeros pasos (desmontaje) y no pierdas los tornillos! La Paperwhite es una tableta resistente que se puede dividir en tan solo unos pocos componentes. Esta guía te mostrará en solo cinco breves pasos cómo reemplazar una batería defectuosa.
Qué necesitas
Inserta una herramienta plástica de apertura en las esquinas de la Paperwhite y deslízala alrededor del perímetro del borde para retirar el bisel.
Para ensamblar tu dispositivo, sigue estas instrucciones en orden inverso.
34 personas más completaron esta guía.
Un agradecimiento especial a estos traductores:
100%
¡ Fuzzy_Pickles nos está ayudando a reparar el mundo! ¿Quieres contribuir?
Empezar a traducir ›
7Guía Comentarios
Do you have a source for the battery itself? Thank you.
I’ve done this on two different Kindles with the same result: dead kindle. No matter how long it stays on the charger, the light stays amber. Screen will not change. Hard reset seems to do nothing; the light flashes, but no change. One Paperwhite even got a new motherboard. This is crazy! Is it possible to fix one, do I have to just buy another!?
I'm probably 7 years too late but this was the case with one I got from Goodwill and plugging it into a higher amperage charger (2.4A) seemed to do the trick. When you plug it in it charges until there is enough power for it to boot up and when that happens it ends up draining the little bit that was there so it just gets stuck in a loop. You just have to give it more power to work with.
Hi Adam,
I have the same issue, the light is orange but the Kindle won’t turn on. I ordered the battery at www.batteryupgrade.com. But they have some misleading info on their website so they sent me the wrong battery even if it states that it supports Kindle Paperwhite 2012. Check the connections on original and on the new battery. In my case the battery looks the same, but the connections doesn’t. Now I’m waiting for the new one …
Regards.
Did replacement of battery help you to resolve problem?
