Introducción
Since the original part is made of brass and thus too soft for its intended purpose, it is subject to high wear (even when driven with the standard plastic main gear).
Qué necesitas
If there is an additional main sprocket and engine sprocket protection (not serial condition), this must be removed first. To do this, all marked screws must be turned out with a PH1 screwdriver. These are two different screws.
When the vehicle is in the delivery state, only the red marked screw has to be removed.
To loosen the pinion, the grub screw that fixes it to the motor output shaft must be loosened. For this you need a 1.5mm Imbus.
The rod to adjust the fall on the right rear wheel (direction of travel) should be solved on the vehicle side to remove the old part better (in the photo already done) and the new one to lead.
Then it can simply be pulled back and removed
Please dispose of the old part properly! Best in the metal container on the recycling center, so it can be recycled. It has nothing to do with household waste. Work the steps in reverse order to reassemble the vehicle.
Un agradecimiento especial a estos traductores:
100%
¡ irlanda nos está ayudando a reparar el mundo! ¿Quieres contribuir?
Empezar a traducir ›
