Saltar al contenido principal
RedOctane X-Plorer Whammy Bar Replacement
Qué necesitas
  1. RedOctane X-Plorer Whammy Bar Replacement, Rear Case: paso 1, imagen 1 de 2 RedOctane X-Plorer Whammy Bar Replacement, Rear Case: paso 1, imagen 2 de 2
    • Remove the strap by pulling it off of the mounts located on the body and neck.
  2. RedOctane X-Plorer Whammy Bar Replacement: paso 2, imagen 1 de 3 RedOctane X-Plorer Whammy Bar Replacement: paso 2, imagen 2 de 3 RedOctane X-Plorer Whammy Bar Replacement: paso 2, imagen 3 de 3
    • Remove the nine 12mm Phillips #1 screws around the perimeter of the case with a screwdriver.
    • Remove the two 15mm Phillips #1 screws connecting the body panel to the neck panel with a screwdriver.
    • These screws can also be Torx on some models.
    • Pull off the rear case.
  3. RedOctane X-Plorer Whammy Bar Replacement: paso 3, imagen 1 de 3 RedOctane X-Plorer Whammy Bar Replacement: paso 3, imagen 2 de 3 RedOctane X-Plorer Whammy Bar Replacement: paso 3, imagen 3 de 3
    • Remove the five 12mm Phillips #1 screws along the neck with a screwdriver.
    • Pull off the top shell of the neck to expose the internal features.
  4. RedOctane X-Plorer Whammy Bar Replacement, Whammy Bar: paso 4, imagen 1 de 3 RedOctane X-Plorer Whammy Bar Replacement, Whammy Bar: paso 4, imagen 2 de 3 RedOctane X-Plorer Whammy Bar Replacement, Whammy Bar: paso 4, imagen 3 de 3
    • Remove the two 7mm Phillips #2 screws from the black wire retainer.
    • Pull off the black wire retainer.
  5. RedOctane X-Plorer Whammy Bar Replacement: paso 5, imagen 1 de 1
    • Reach one finger under the guitar to push the whammy bar and its attached components from the case.
  6. RedOctane X-Plorer Whammy Bar Replacement: paso 6, imagen 1 de 2 RedOctane X-Plorer Whammy Bar Replacement: paso 6, imagen 2 de 2
    • Remove both of the plastic side tabs by gently pulling them off.
  7. RedOctane X-Plorer Whammy Bar Replacement: paso 7, imagen 1 de 1
    • Remove the two plastic tabs from the whammy bar casing.
    • Keep the spring connected to the plastic tabs throughout this step.
  8. RedOctane X-Plorer Whammy Bar Replacement: paso 8, imagen 1 de 1
    • Using two hands, remove the spring from the plastic tabs.
Conclusión
3 personas más completaron esta guía.
[deleted]
Miembro Desde 04/18/18
175 Reputación
1 Guía escrita
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 1
Ultimos 7 días: 19
Ultimos 30 días: 96
Todo El Tiempo: 3,582
