Saltar al contenido principal
RedOctane X-Plorer Strum Bar Replacement
Qué necesitas
  1. RedOctane X-Plorer Strum Bar Replacement, Rear Case: paso 1, imagen 1 de 2 RedOctane X-Plorer Strum Bar Replacement, Rear Case: paso 1, imagen 2 de 2
    • Remove the strap by pulling it off of the mounts located on the body and neck.
  2. RedOctane X-Plorer Strum Bar Replacement: paso 2, imagen 1 de 3 RedOctane X-Plorer Strum Bar Replacement: paso 2, imagen 2 de 3 RedOctane X-Plorer Strum Bar Replacement: paso 2, imagen 3 de 3
    • Remove the nine 12mm Phillips #1 screws around the perimeter of the case with a screwdriver.
    • Remove the two 15mm Phillips #1 screws connecting the body panel to the neck panel with a screwdriver.
    • These screws can also be Torx on some models.
    • Pull off the rear case.
  3. RedOctane X-Plorer Strum Bar Replacement: paso 3, imagen 1 de 3 RedOctane X-Plorer Strum Bar Replacement: paso 3, imagen 2 de 3 RedOctane X-Plorer Strum Bar Replacement: paso 3, imagen 3 de 3
    • Remove the five 12mm Phillips #1 screws along the neck with a screwdriver.
    • Pull off the top shell of the neck to expose the internal features.
  4. RedOctane X-Plorer Strum Bar Replacement, Strum Bar: paso 4, imagen 1 de 1
    • Using two hands, gently remove the two string rod fixtures.
  5. RedOctane X-Plorer Strum Bar Replacement: paso 5, imagen 1 de 1
    • Lift up on the strum bar to remove it from the guitar.
  6. RedOctane X-Plorer Strum Bar Replacement: paso 6, imagen 1 de 2 RedOctane X-Plorer Strum Bar Replacement: paso 6, imagen 2 de 2
    • Remove the string rod by gently pulling it out of the strum bar.
Conclusión
4 personas más completaron esta guía.
Jared McMullen
Miembro Desde 04/18/18
276 Reputación
1 Guía escrita
Equipo
Cal Poly, Team S17-G1, Livingston Spring 2018 Miembro de Cal Poly, Team S17-G1, Livingston Spring 2018
CPSU-LIVINGSTON-S18S17G1
3 Miembros
9 Guías creadas
2 comentarios
I had a squeaking strum bar so I followed this guide to dismantle and clean the parts. Other than the one step missed in the guide it was easy to follow. It also stopped the squeaking!
Zachary Avery - Contestar
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 3
Ultimos 7 días: 22
Ultimos 30 días: 51
Todo El Tiempo: 3,589
