Saltar al contenido principal
RedOctane X-Plorer Motherboard Replacement
Qué necesitas
  1. RedOctane X-Plorer Motherboard Replacement, Rear Case: paso 1, imagen 1 de 2 RedOctane X-Plorer Motherboard Replacement, Rear Case: paso 1, imagen 2 de 2
    • Remove the strap by pulling it off of the mounts located on the body and neck.
  2. RedOctane X-Plorer Motherboard Replacement: paso 2, imagen 1 de 3 RedOctane X-Plorer Motherboard Replacement: paso 2, imagen 2 de 3 RedOctane X-Plorer Motherboard Replacement: paso 2, imagen 3 de 3
    • Remove the nine 12mm Phillips #1 screws around the perimeter of the case with a screwdriver.
    • Remove the two 15mm Phillips #1 screws connecting the body panel to the neck panel with a screwdriver.
    • These screws can also be Torx on some models.
    • Pull off the rear case.
  3. RedOctane X-Plorer Motherboard Replacement: paso 3, imagen 1 de 3 RedOctane X-Plorer Motherboard Replacement: paso 3, imagen 2 de 3 RedOctane X-Plorer Motherboard Replacement: paso 3, imagen 3 de 3
    • Remove the five 12mm Phillips #1 screws along the neck with a screwdriver.
    • Pull off the top shell of the neck to expose the internal features.
  4. RedOctane X-Plorer Motherboard Replacement, Auxiliary Port: paso 4, imagen 1 de 3 RedOctane X-Plorer Motherboard Replacement, Auxiliary Port: paso 4, imagen 2 de 3 RedOctane X-Plorer Motherboard Replacement, Auxiliary Port: paso 4, imagen 3 de 3
    • Remove the two 10mm Phillips #1 screws from the auxiliary port board using a screwdriver.
    • Gently lift up on the auxiliary port to remove it from the case.
  5. RedOctane X-Plorer Motherboard Replacement, RJ-14 Connector: paso 5, imagen 1 de 3 RedOctane X-Plorer Motherboard Replacement, RJ-14 Connector: paso 5, imagen 2 de 3 RedOctane X-Plorer Motherboard Replacement, RJ-14 Connector: paso 5, imagen 3 de 3
    • Remove the two 10mm Phillips #1 screws from the RJ-14 connector board.
    • Lift the RJ-14 connector to remove it from the case.
  6. RedOctane X-Plorer Motherboard Replacement, Keys: paso 6, imagen 1 de 3 RedOctane X-Plorer Motherboard Replacement, Keys: paso 6, imagen 2 de 3 RedOctane X-Plorer Motherboard Replacement, Keys: paso 6, imagen 3 de 3
    • Use a screwdriver to remove the 10 mm Phillips #1 screws from the key sensor board.
    • Lift up on the key sensor board to remove it from the guitar neck.
    • When using the screwdriver, make sure to avoid puncturing the wires.
  7. RedOctane X-Plorer Motherboard Replacement: paso 7, imagen 1 de 1
    • Using your fingers, remove the rubber pad to expose the colored keys.
  8. RedOctane X-Plorer Motherboard Replacement: paso 8, imagen 1 de 2 RedOctane X-Plorer Motherboard Replacement: paso 8, imagen 2 de 2
    • Reach one finger under the guitar to push the key out of the casing.
    • Repeat this step for the four remaining keys.
  9. RedOctane X-Plorer Motherboard Replacement, Strum Bar Sensor Board: paso 9, imagen 1 de 3 RedOctane X-Plorer Motherboard Replacement, Strum Bar Sensor Board: paso 9, imagen 2 de 3 RedOctane X-Plorer Motherboard Replacement, Strum Bar Sensor Board: paso 9, imagen 3 de 3
    • Use a screwdriver to remove the four 14mm Phillips #1 screws around the perimeter of the strum bar sensor board.
    • Lift up on the strum bar sensor board to remove it from the case.
  10. RedOctane X-Plorer Motherboard Replacement, Whammy Bar Sensor: paso 10, imagen 1 de 3 RedOctane X-Plorer Motherboard Replacement, Whammy Bar Sensor: paso 10, imagen 2 de 3 RedOctane X-Plorer Motherboard Replacement, Whammy Bar Sensor: paso 10, imagen 3 de 3
    • Remove the two 7mm Phillips #0 screws.
    • Using your fingers, remove the black wire retainer.
  11. RedOctane X-Plorer Motherboard Replacement: paso 11, imagen 1 de 2 RedOctane X-Plorer Motherboard Replacement: paso 11, imagen 2 de 2
    • Using one hand, remove the whammy bar and its attached components from the case.
  12. RedOctane X-Plorer Motherboard Replacement: paso 12, imagen 1 de 1
    • Using two hands, remove the whammy bar sensor.
  13. RedOctane X-Plorer Motherboard Replacement, Motherboard: paso 13, imagen 1 de 3 RedOctane X-Plorer Motherboard Replacement, Motherboard: paso 13, imagen 2 de 3 RedOctane X-Plorer Motherboard Replacement, Motherboard: paso 13, imagen 3 de 3
    • Remove the four 10mm Phillips #1 screws around the perimeter of the motherboard with a screwdriver.
    • Lift the motherboard to remove it from the case.
Conclusión
Una persona más ha completado esta guía.
Riley
Miembro Desde 04/18/18
649 Reputación
7 Guías creadas
Equipo
Cal Poly, Team S17-G1, Livingston Spring 2018 Miembro de Cal Poly, Team S17-G1, Livingston Spring 2018
CPSU-LIVINGSTON-S18S17G1
3 Miembros
9 Guías creadas
Un comentario
Where can I but a replacement board?
Matthew - Contestar
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 3
Ultimos 7 días: 12
Ultimos 30 días: 51
Todo El Tiempo: 2,430
